Exhaust Leak (Pics)
Exhaust Leak (Pics)
I've have been hearing this exhaust leak for a while now so I took a couple pics I'm not sure where its exactly coming from. I had the turbo up pipes replaced lil over a year ago. I'm gona try and put pics on there from photobucket.
Any idea on where its comin out at from these few pics?
They come from the factory without manifold gaskets but they are available for an exhaust manifold R&R. If the manifold is not to badly warped gaskets may stop the leak. If not the manifolds need to be decked or replaced. Peter (Duck Fan) replaced his manifolds with ceramic coated ones he got HERE. I'm sure you can also get them without the ceramic coating. Peter's write-up Thread Link.
Replacing the manifolds is not as bad as you would think. Jack up the front of the truck and support it with jackstands. Remove the wheels. Remove the fender liners. All 8 bolts on each manifold are right there in front of you. Plenty of PB Blaster. Torque on the manifold bolts to 38 - 42 ft-lbs. It is recommended to use new bolts.
My experiences are here in this thread: https://www.ford-trucks.com/forums/8...eak-fixed.html
Edit: Robin is fast
Edit: Robin is fast
A lot of manifold leaks are caused by the bolts loosening over time. You can resurface them, doing only the one you need.
