32's?
32"s should fit, but swampers might get you in trouble. The lugs are larger than that of a standard tire, which will probably rub. One thing you can do is shim the bumper out a bit. That might give you a bit more clearance. One thing you might have to look at is backspacing. 32"s normally fit, but you might need to change rims to accomplish what you want. I am sure others will chime in here.
Rich
Rich
Originally Posted by rockinkcollins
my 95 has the stock 31x10.5s on the stock chrome wheels. i want bigger more aggressive tires, but no lift or cutting. will 32x11.5's fit with NO rubbing?
im thinking swampers
Warr
Originally Posted by JBronco
Yeah 33's will fit but IMHO it looks stupid without a lift, and even 31's rub on full lock anyway with stock rims. And 33's with no lift will bottom out on hard bumps. 31's don't, not sure about 32's.
I dont' think I will find them.
Imho
My 88 Has 32x 10.5" All terrains and it rubs at full lock especially over bumps,
my 10.5's cut a bit on the front fenders if I'm really off-camber
my 81 had nearly bald 35's that rub less (on the frame and rad. arm) than my 32's buy they are on very offset rims and stickout the fenders, It looks great, but not to the police.
btw. there's no sheet metal in the way on my 81, the fenders are cut larger.
