The switch on the cab works just fine, when i switch it over, the truck is not getting any gas and goes to die and i have to switch it back really quick so it does not die
Both of my Trucks have dual tanks, 97 F250 HD 4X4 and a 92 F350 4X4, both have the identical problem. Both rear tanks, gauges work as they should, both front tanks supply fuel but the gauges does not work.
If the gauge is always on empty more than likely the floats have sunk.
Ok. I have replaced the front fuel pump and sending unit. I have replaced the fuel selector switch. What else could cause the problem. I took truck on test run, and it did fine except when going up hill. It started to sputter and starve for fuel. It is really starting to tick me off. I do not know what else to replace to fix this problem. If anyone has any ideas please let me know. Thanks. Happy New Year to everyone.
I have the same issue and now both the front and back tank isn't working. Did you ever find out the cause? I replaced the fuel pump and fuel relay switch.
