Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Virginia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Virginia Chapter Join Chapter, Leader: archtaan
  #1 (permalink)
Old 04-12-2010, 12:55 PM
r23k4u1968 r23k4u1968 is offline
Garage is empty, add now
r23k4u1968 is starting off with a positive reputation.
desperate need for martinsville area help on solenoid switch or something else wrong
Hi all! My name is rob and I am trying very hard to fix my problem and I will give you a quick description and Please email me at r23k4u@yahoo.com or private here please so I don’t have to search. The reason I am desperate is my truck is sold but now have an easy problem I thought.fficeffice" /><O></O>
<O></O>
Okay from start to finish problem.<O></O>
1. CAME TO TRUCK TO CRANK IT UP AND NOTHING, NO LIGHTS, NO TURN OVER, NO CHARGE ANYWHERE.<O></O>
2. OKAY EASY ENOUGH, NEW BATTERY, WENT TO CRANK, IT NEVER TURNED OVER NOR ANY LIGHTS, ETC, ETC. WENT TO CHECK CABLES AND THE WIRE TO THE NEG. SAID OF SOLENOID STARTED SMOKING AND THEN IT MELTED.<O></O>
3. WELL TRIED TO CUT AND REPLACE THAT SPOT, HOOKED IT BACK UP, BURNT OUT AGAIN. I AM STUCK GUYS!! I HAVE REPLACED SOLENOID SWITCH, AND THE STARTER WORKS FINE.<O></O>
4. SO GUYS IS IT A SHORT SOMEWHERE OR WHAT PLEASE??<O></O>
<O></O>
I HAVE TILL TOMORROW TO GET FIXED GUY IS PICKING IT UP. IT IS A 1970 FORD TRUCK, 302 AUTOMATIC.<O></O>
<O></O>
PLEASE SOMEONE HELP ME WILL YOU??<O></O>
ROB<O></O>
  #2 (permalink)
Old 04-12-2010, 03:24 PM
MissIndependent's Avatar
MissIndependent MissIndependent is offline
MissIndependent is gaining momentum as a positive member of FTE.MissIndependent is gaining momentum as a positive member of FTE.
i am a little confused...battery cables are good and it is the wire to the solenoid that is melting? have you pulled the starter? sometimes they will even test good when they're not...and if u don't replace them, will give u months of misery! lol, i speak from experience!
__________________
"she's not crazy, just a little misunderstood"
1996 F250 XLT 7.3L PSD SC/LB 4x4, auto, 4.10s, 4" suspension lift on 37" Goodyear Wrangler MTs, 6637 air filter, 208k+ mi and counting
Plotting: stacks, gauges, tw chip, cat/muffler delete, and more that won't fit
  #3 (permalink)
Old 04-12-2010, 10:30 PM
Blue Chevy's Avatar
Blue Chevy Blue Chevy is offline
Blue Chevy is starting off with a positive reputation.
sounds to me you got a hot wire grounding out
Tags
r23k4u
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
