R&R Y-Pipe withough removing turbo? - Ford Truck Enthusiasts Forums
Old 04-12-2010, 12:43 PM
KRDiesel's Avatar
KRDiesel KRDiesel is offline
KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.
I think I have read somewhere that you can replace the y-Pipe without removing the turbo. Does anyone have a procedure?
Old 04-12-2010, 12:48 PM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud of
I did mine with removing the turbo. I didn't know you could do it without removing the turbo.
Old 04-12-2010, 03:26 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
I'm not sure how you'd get it out without removing the turbo as I don't think there's any way to wiggle it out underneath. Removing the turbo is SO much easier than trying to fight it out underneath anyway and at MOST all you need is the $10 turbo gasket kit. You have an 03 so it's a LOT easier than the later models IMHO. If you're replacing the y-pipe because of a broken flex bellows on the passenger side then that can be done without removing the turbo but it's still a PITA.
Old 04-12-2010, 04:20 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is online now
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
Quote:
Check this out.
http://www.ford-trucks.com/forums/77...tructions.html
Old 04-12-2010, 05:18 PM
Quote:
Originally Posted by amdriven2liv View Post
From what I'm reading all I see him removing is the up-pipe not the whole y-pipe assy. Nothing at all like removing the complete y-pipe. I'm not saying it can't be done, it's just a LOT easier to remove the turbo to get it out and probably a lot less time in the long run. It only takes about 30 minutes to remove a turbo (with a little practice).
Old 04-13-2010, 02:16 PM
desertt5 desertt5 is offline
desertt5 is starting off with a positive reputation.
Didn't you just fix yours? What happened?
Old 04-13-2010, 02:49 PM
KRDiesel's Avatar
tas working on it, but i broke a few bolts and ran out of time. So i am restarting the project.
Old 04-13-2010, 04:10 PM
Gotcha. At least it warmer now.
Need a little help..... lkforney11 6.0L Power Stroke Diesel 3 09-01-2016 01:44 AM
Dynomax Y-Pipe powerstroke8806 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 03-29-2016 02:09 AM
Y-pipe Leak Craig.Parks 6.0L Power Stroke Diesel 3 04-12-2013 05:23 PM
aftermarket y-pipes Thumper19 1987 - 1996 F150 & Larger F-Series Trucks 5 06-08-2012 09:56 AM
In the middle of pulling turbo...3 quick questions! AndeyHall 6.0L Power Stroke Diesel 19 07-11-2011 11:34 PM
Tags
03, 2003, 60, 60l, buy, f250, f350, ford, gasket, pipe, powerstroke, removal, removing, replacement, turbo, ypipe
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
