Best mods?? - Ford Truck Enthusiasts Forums
Best mods??
Old 04-12-2010, 10:03 AM
jarwood jarwood is offline
jarwood is starting off with a positive reputation.
Best mods??
Ive got a 2000 f-350 SBCC (auto) what are the best mods for my money?
I use it as a daily driver and to haul a travel trailer for camping. Have a small budget and looking for advise on how to build more power. I have a set of guages (pyro, tran, boost) 50 hp Painless Tuner, bigger trans pan (mag-tec?) AFE stage 1 and a Banks trans-command. Any advise on what else to do??
Old 04-12-2010, 10:14 AM
Duck Hunter81's Avatar
Duck Hunter81 Duck Hunter81 is offline
Duck Hunter81 is starting off with a positive reputation.
I would throw on some 4" exhaust and a DP Tuner. I have never heard of the 50 hp Painless Tuner.
Those would probably be the best for the power mods for a budget but the others will be around soon with more tips.
Old 04-12-2010, 10:49 AM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
See sig...
But seriously, it depends on what you want to do with your truck. A daily-driver/tow-mule would take many of the same mods you see below, minus the large injectors. Stage 1s/2s eventually would be nice, but the below mods as you can afford them would be good. I did them in the order that you see them listed, but I would do trans mods before custom tuning if I were to do it over again...
Old 04-12-2010, 03:00 PM
12pump 12pump is offline
12pump is starting off with a positive reputation.
subscribing.
Old 04-12-2010, 03:45 PM
PwerStroke99's Avatar
PwerStroke99 PwerStroke99 is offline
PwerStroke99 has a very good reputation on FTE.PwerStroke99 has a very good reputation on FTE.PwerStroke99 has a very good reputation on FTE.
whats your hp goals? if u want 450+ look at my sig
Old 04-13-2010, 02:51 AM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
My truck is not my daily driver and I neglected it for few year by letting it sit under the oak for months at the time.
But it is all stock with single upgrade FROM wicked wheel to newer one.
Not only the engine at 207k is bulletproof (not few sensors on it) but with better oil and higher tire pressure my mpg went up almost 30%.
I plan to drive the truck way above 500k, so I am staying away from tuners.
Old 04-14-2010, 12:39 AM
GEugeneS GEugeneS is offline
GEugeneS is starting off with a positive reputation.
I think you would start with decent gauges, like from IssPro. The trans temp in the dash is almost useless on my 02. I also like to monitor the exhaust temp when pulling, and its just fun to see the boost. After that add cooling to the trans especially if pulling any weight and then maybe a DP tuner. You don't have to go big power with it. The best thing about mine is the shifting and the exhaust brake. Great truck.
Old 04-14-2010, 12:50 AM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01 diesel-fitter-bum01 is offline
diesel-fitter-bum01 has a good reputation on FTE.diesel-fitter-bum01 has a good reputation on FTE.
Joe are you still on your stock tq converter and head studs?
Old 04-14-2010, 07:02 AM
HD Rider's Avatar
HD Rider HD Rider is offline
HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.
4" exhaust
Replace that tuner with one from DP, PHP, BTS ect...
Ditch the Trans Command for a BTS or John Wood valve body, or a Transgo Tugger kit.
Wicked Wheel for the turbo
6.0L trans cooler
08 rear diff cover
Here is a good resource for you Roadside Help Network - Guides, Maintenance & Mods
Old 04-14-2010, 09:30 AM
CampSpringsJohn's Avatar
CampSpringsJohn CampSpringsJohn is offline
CampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputation
Intake, which you have already done.
A 4" exhaust to keep things cool.
A set of gauges to monitor things, which you have done.
A transgo tugger kit for the tranny.
A tranny cooler, a 6.0, or an aftermarket cooler. Your tranny will need it for towing.
The above list will do very little in boosting power. What it will do is set you up for a tuner if you choose. If not, at the very least it will enable your truck to operate at peak efficency, running cooler, with less chance of tearing anything up.
There are several good tuners out there. DP Tuner is a sponsor of this site, but you also have Power Hungary Performance, Swamps, Beans, Tony Wildman, and a few others. Any of these folks can make a custom chip/tuner for your specific needs. They are not "one size fits all" type operations. They will make a chip specifically for your truck, taking into consideration any mods you have done, and any future mods you may wish to do down the road, as well as your needs. If/when the time comes for going this route, do some research and make a good decision. The other mods listed are supporting mods for a chip, so I would do those first. As I said before, even if a chip is not for you, I'd still do the mods.
Old 04-15-2010, 09:42 AM
Thanks for the good info!! I talked with Clay at Riffraff yesterday and he suggested alot of the same things. All I have to do is start saving up $$$$$$$
Thanks again FTE
New mods in what order? mcali2 1994.5 - 1997 7.3L Power Stroke Diesel 15 06-23-2016 01:32 AM
Trans cooler Maddy 1999 to 2016 Super Duty 4 11-18-2015 04:59 PM
6637 filter mod questions jmcgill 1999 - 2003 7.3L Power Stroke Diesel 10 05-13-2010 07:01 PM
putting a 460 in my 69 ford f100 BrandynBohlman 1967 - 1972 F-100 & Larger F-Series Trucks 6 03-31-2009 04:25 PM
79 with a diesel motor hjoe 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-28-2007 10:31 PM
Tags
50, 60, 73, area, bay, diesel, dp, f250, ford, mod, modification, modifications, mods, truck, trucks, tuner, tuning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
