Post up a pic of what your truck looks like TODAY! - Page 2 - Ford Truck Enthusiasts Forums
Old 04-11-2010, 10:28 PM
ford to the bone's Avatar
ford to the bone ford to the bone is offline
ford to the bone
ford to the bone has a good reputation on FTE.ford to the bone has a good reputation on FTE.
i am running 36x13.50x17s
Old 04-11-2010, 10:30 PM
4x4cody's Avatar
4x4cody 4x4cody is offline
4x4cody is starting off with a positive reputation.
thats a badass truck "ford to the bone"
Old 04-11-2010, 10:33 PM
ford to the bone
thanks man i am building another on
Old 04-11-2010, 10:36 PM
ford to the bone
this is my other truck
Old 04-11-2010, 10:37 PM
ford to the bone
thats the other truck i am working on
Old 04-11-2010, 10:44 PM
rancheronut's Avatar
rancheronut rancheronut is offline
rancheronut is starting off with a positive reputation.
it a 1978 F350 factory DUMP truck. it only has 46,902 miles on her. she was bought new for the MSU Bozeman in 2/78. it was last used to haul a water tank around campus to water there trees. when I got it . you tell life was not grand there ,from all the summer student driver .
I pulled the 351M because it smoked and put in a built up 400. that I had sitting around. now it a fast bump truck. .
later, I found out .the reason the 351 smoked .was from all the sitting and great care it got for the msu, there was 3 cylinder , that the rings where stuck in the pistons. the block only has most of 0.002 tapper in the cylinders wall and still had the factory plastic timing chain gear on. I plan to rebuild the 351M but with a 400 crank.so the truck CAN have it factory number parts back.
Old 04-11-2010, 10:47 PM
ford to the bone
thats not a bad truck
Old 04-11-2010, 11:01 PM
RVDan's Avatar
RVDan RVDan is offline
RVDan is starting off with a positive reputation.
Is yesterday close enough to today?
Its sitting there waiting for me to get around to working on it. Needs a motor swap, I cooked it last year after a radiator failure. The new rear springs are here waiting to go in as well. I may convert it to gas this time around instead of propane, its getting hard to buy vehicle propane in the US and I plan to do several trips south this year. Probably getting a large portion of the body swapped too, my parts truck has much better doors and the bed has the toolbox in the side which this one doesn't.
Old 04-11-2010, 11:09 PM
ford to the bone
that works it fine that makes me miss my old extened cab f250
Old 04-11-2010, 11:31 PM
CleanPortland CleanPortland is offline
CleanPortland is starting off with a positive reputation.
http://www.ford-trucks.com/forums/album.php?u=482077
Here is the gallery with my pics the ones outside taken today.
Old 04-11-2010, 11:49 PM
Witty73's Avatar
Witty73 Witty73 is offline
Witty73 is gaining momentum as a positive member of FTE.
Well, I just picked this barn find up a few days ago. In fact two days ago it was oxidized and faded horribly and looked like this:
Today after a bath and some elbow grease it looks like this:
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Quote:
Originally Posted by 79 f350ts View Post
sweet looking frame!!!!!!!
Thanks, as you can see I've got a lot of work ahead of me.
  #28
Old 04-12-2010, 12:21 AM
4x4cody's Avatar
dam "Witty73" i was lookin forward to seeing that thing washed and it looks like a beauty
  #29
Old 04-12-2010, 01:08 AM
spudgunman's Avatar
spudgunman spudgunman is offline
spudgunman is starting off with a positive reputation.
Quote:
good looking truck
  #30
Old 04-12-2010, 04:54 AM
f100racing's Avatar
f100racing f100racing is offline
f100racing is gaining momentum as a positive member of FTE.f100racing is gaining momentum as a positive member of FTE.
Here's mine after cruising for the weekend.
4 Questions for y'all Hobby welder 1987 - 1996 F150 & Larger F-Series Trucks 16 05-15-2016 06:46 PM
What brand of ball joints are the best? Cbartlett1988 1987 - 1996 F150 & Larger F-Series Trucks 16 02-04-2015 12:01 PM
M5OD problems 85F350IDI 1987 - 1996 F150 & Larger F-Series Trucks 6 01-26-2015 10:03 AM
Calling all supercabs who tow!!! old blue beast 1973 - 1979 F-100 & Larger F-Series Trucks 0 08-01-2013 02:00 AM
headers to fit my truck from l&l terdmang 1973 - 1979 F-100 & Larger F-Series Trucks 9 09-01-2012 06:33 PM
Tags
302, 73, 77, 83, bought, enthusiasts, f100, find, ford, gflo, original, pic, post, solenoid, today, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
