AIH delete..Removed Solenoid, BLUE WIRE??
Old 04-18-2010, 01:28 PM
PsD007.3's Avatar
PsD007.3
PsD007.3 is offline
i deleted AIH and i also got rid of the solenoid that controls it..soo i removed the red and black wires completely from the truck..i did this cause i figured it was pointless to remove the AIH and leave the solenoid there just with 2 wires on it..i electrical taped all the wires and just tucked them down in the engine valley..i will only get a soft code correct??? i want to keep the solenoid off the truck should i just put a resistor on the blue wire and take it to ground to be safe?? and if soo what size resistor should i buy??
Old 04-18-2010, 02:19 PM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is offline
I would measure the impedence on the windings for the relay and then go get a resister that is slightly more resistance than the relay.
Old 04-18-2010, 02:48 PM
PsD007.3's Avatar
PsD007.3
PsD007.3 is offline
i already got rid of everything except the 2 wires i took off the AIH the solenoid and AIH and thrown away..removing that solenoid definitely cleaned the valled up a little bit..would just puttin a resistor on the blue wire and then the other end to ground?? an if i dont it wont ever set a ses light?? it will just throw a soft code correct?? i heard the resistor is 470 ohms 2 watts??
Old 04-18-2010, 03:14 PM
PsD007.3's Avatar
PsD007.3
PsD007.3 is offline
i guess what my question is..if i just leave the solenoid out and the wires all just electrical taped off and not put a resistor on the blue wire it will never throw a SES dash light will it?? it will only just be a soft code?? and it wont ever hurt if i have to run any type of dianogstics test??
Old 04-18-2010, 03:37 PM
Kwikkordead
I run without a resister at all.
Just tape off the wire.
No SES light, but yes it does store a code.
Old 04-18-2010, 08:52 PM
PsD007.3's Avatar
PsD007.3
PsD007.3 is offline
yea but did you also take out the solenoid? and will it affect getting any type of test run on my truck if it does store a code??
Old 04-18-2010, 10:16 PM
snakedoc's Avatar
snakedoc
snakedoc is offline
i would think that it would not affect a test on the truck.
BWST
62
03-01-2019 11:57 AM
ryanboisture
03-06-2016 07:01 PM
Absolute
01-20-2016 02:15 PM
Backdraft-14
03-17-2012 05:16 PM
Pocket
45
10-24-2008 08:08 PM
Quick Reply: AIH delete..Removed Solenoid, BLUE WIRE??
