can i use 10-40 in my 91 f150 V8 5.0L - Ford Truck Enthusiasts Forums
Old 04-11-2010, 12:38 PM
Offroadracer426 Offroadracer426 is offline
Offroadracer426 is starting off with a positive reputation.
I wanna know if i can use high milage 10w 40 for my 1991 F150, its a v8 5.0L
Old 04-11-2010, 12:52 PM
jr32560's Avatar
jr32560 jr32560 is offline
jr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to behold
Quote:
that's what I use in my 1990 302~~~~have been for over 8 years now -she's a leaker
Old 04-11-2010, 01:12 PM
Quote:
how many quarts should i use all 6 or 5 and a half, mine leaks too, i gotta do my rear main seal
Old 04-11-2010, 05:25 PM
DreadyDiggs's Avatar
DreadyDiggs DreadyDiggs is offline
DreadyDiggs is starting off with a positive reputation.
Use 6. And of course you can use it. It's just a little thicker at operating temp than 10W-30. Same thickness at startup.
My Supra has 10W-40 in it right now, and calls for 10W-30. Used it after someone said it'd help with the lash adjuster (lifter) noise. The 5M engine is known for being noisy and the thicker oil helped quiet it down.
Thicker oil harder to pump more work for the engine and more protection. Thinner oil the opposite.
Old 04-11-2010, 06:01 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
for summer that is fine but not for winter in ny.
Old 04-11-2010, 06:05 PM
ymeski56's Avatar
ymeski56 ymeski56 is offline
Der Postmeister
ymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputation
USE 1 QT of Lucas oil stabilizer w/ whatever oil you use!
Old 04-11-2010, 11:28 PM
Quote:
I've never added anything to any oil I've used. Lucas is some thick stuff, maybe it does it's job better than just upping your oil weight, maybe it don't. I haven't used it. But the folks that use it and Slick 50 and the like swear by them haha.
I'm gonna pour seafoam in my oil and drive about 50 miles before draining it, and see what that does, and that'll be the first additive I've ever put in my oil besides what comes in the quarts of oil themselves.
Old 04-12-2010, 01:50 AM
xpumper xpumper is offline
xpumper is starting off with a positive reputation.
Use 10-40?? Go BIG!!
1995 F-150, 155k for miles;
5.0, Auto, 2 wheel drive.
In the Winter (in Southern California) I use 6 qts of Castrol 20-50, and for the Summer, trips to the Desert, etc, I use Valvoline Racing 50 wt, 5 qts with a measured top-off of Lucas Treatment.
Change the filter ONLY, fill the new one with LUCAS, and continue. I only change oil 3 times a year. No rattle, no lifter tick cold, and I'm hoping for another good year. This is my Company Truck, and Home driver too.
Bearings get worn; Motors get hot. I have 33" BFG's, and didn't re-gear. (my fault) But she still starts and runs quiet, thru the muffler!
Is a 5.0L flywheel the same as a 5.8L flywheel RustyBarnard Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 11 08-11-2016 08:47 PM
2011 F-150 5.0L Flowmaster (True Duel or Single Duel)? 640 CI Aluminum FORD Exhaust Systems 1 11-16-2011 10:38 AM
1989 Ford Tire Sizes Aune163rd 1987 - 1996 F150 & Larger F-Series Trucks 4 01-12-2011 09:56 PM
Max trailer pull on 1996 Ford F150 5.0L V8 *keys* 1987 - 1996 F150 & Larger F-Series Trucks 39 06-05-2008 10:39 PM
5.0l V8 Efi Ohv Drof96 Performance & General Engine Building 3 03-02-2003 04:33 AM
Tags
1040, 10w30, 150, 1990, 1991, 50l, 91, changingoilin95f150wv8, codes, engine, f150, ford, oil, quarts, truck, type, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
