Brand new large chamber iron D3-style 429/460 head castings with modern exhaust ports - Ford Truck Enthusiasts Forums
Old 04-11-2010, 10:18 AM
Dezertracer's Avatar
Dezertracer Dezertracer is offline
Dezertracer is starting off with a positive reputation.
I was checking out another Ford website and you won't believe what is now available for us big block Ford fans: BRAND NEW large chamber iron D3-style 429/460 head castings with modern exhaust ports!
I was excited to see that there is another choice for enthusiasts out there who need a casting like these for a truck, motorhome, street machine or class restricted racing.
I do not know anything more about these heads than the information below that I copied and pasted from the other webite. Check out the link near the bottom or call Scotty Johnston at RHP for more information.
These brand new castings feature:
Completely revised and updated standard location exhaust port flowing 180 cfm as cast.
200 cfm with bowl blend
240 cfm with large valve and port work.
Hardened seat inserts on both intake and exhaust.
Additional material around exhaust port bolt hole bosses.
Additional material cast in above valve seats intake and exhaust.
95 cc combustion closed chamber.
Slotted oem style rocker pedestals accept stock rockers or aftermarket bolt down rockers.
Uses standard 26 autolite spark plug like the OEM version.
.380" thick deck. Can be milled down to 88 cc's.
OEM intake port configuration with additional cross section at pushrod pinch and short turn radii.
Ideal for propane or CNG use.
Suitable for HD and motor home / heavy towing use.
Flow rates with large valves and portwork will support 750 + HP in a max effort pulling or racing application which is class restricted to iron heads.
See link for more information...
RHPD3Index
http://reincarnation-automotive.com
Scotty J. AKA The "Mad Porter"
Re in"Car"nation High Performance
Tacoma, WA . 98445
253-988-6648
Old 04-12-2010, 03:58 AM
Slip ford man's Avatar
Slip ford man Slip ford man is offline
Slip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud of
They look good, nice to have another option...I wonder about the alloy and I'm guessing China. But again they do look/sound good
Old 04-12-2010, 02:02 PM
The "Mad Porter"'s Avatar
The "Mad Porter" The "Mad Porter" is offline
The "Mad Porter" is starting off with a positive reputation.
Talking
Quote:
Cylinder heads were redesigned in the US, Cast in China and machined in the US as the scat line of products are.
The alloy has less nickle. The casting quality, detail and finish are all very good and are reasons why I elected to carry them in addition to a very good exhaust port design.
Old 04-12-2010, 05:50 PM
bigdan1979f-250's Avatar
bigdan1979f-250 bigdan1979f-250 is online now
bigdan1979f-250 is starting off with a positive reputation.
How much do a set go for and do they have plans to make any 75cc chambers with stud mounted rockers like a set of 1968 heads?
Old 04-13-2010, 09:21 PM
eagle275's Avatar
eagle275 eagle275 is offline
eagle275 is starting off with a positive reputation.
very nice!
Old 04-14-2010, 10:45 PM
Bern_F150_4x4's Avatar
Bern_F150_4x4 Bern_F150_4x4 is offline
Bern_F150_4x4 is gaining momentum as a positive member of FTE.
Purdy, let's see a build and dyno test with um. How long have they been out and is anyone using them? As stated, it would be nice if they had smaller combustion chambers and screw in studs. A moderate bump in compression (maybe 1 to 1.5 points?) would be a nice addition to the improved flow numbers. I suppose you could cut them, but that is an added expense and opens a can of worms with valve train and intake manifold geometry correct? I want torque and lots of it!
Old 05-05-2010, 12:29 PM
wyoming4x4's Avatar
wyoming4x4 wyoming4x4 is offline
wyoming4x4 is gaining momentum as a positive member of FTE.wyoming4x4 is gaining momentum as a positive member of FTE.
Would like to see some flow number's?
All the flow numbers showing are at .800lift. I would like to see some numbers around .500. this is where most towing cam run around. Looks like a great product but need some more info. thanks from wyoming. Also are the heads flowed at 28"water or at 14"water not mentioned? Probably at 28" just want to be sure.
Old 05-05-2010, 08:16 PM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Deck the block, not the heads.
Pistons are too far in the hole to start with.
I will be checking out the "other" forum for more info on these heads with their improved exhaust ports.
Quote:
Thanks for the heads up Dezertracer.
Old 05-05-2010, 11:07 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
It's nice to see a iron D3 with a exhaust port that doesn't have the smog in it. Would have been nice if they would have been machined for studs and guide plates though.
Old 05-16-2010, 12:26 PM
brown79 brown79 is offline
brown79 is starting off with a positive reputation.
i read somewhere that these things where made as replacement heads for 460 based industrial air compresors. hence the stock valvetrain
1997 F-350 460 Towing Mods Update Dezertracer Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 11 10-08-2012 12:34 AM
Bought yesterday........ bigdaddyII 2009 - 2014 F150 16 07-11-2012 08:25 AM
Question on F-350 460 rocker arms Dezertracer 1987 - 1996 F150 & Larger F-Series Trucks 5 11-16-2011 10:16 AM
1997 F-350 460 Towing Mods Update Dezertracer 1987 - 1996 F150 & Larger F-Series Trucks 5 03-08-2010 10:55 PM
Valve spring installation question Dezertracer Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 04-13-2009 04:06 PM
Tags
429, 429460, 460, big, block, castings, d3, engines, ford, head, heads, iron, ported, reman, sound, tacoma, wa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
