Completed Major Restoration & Modification Projects, Announce only NO replies
#78
contact info
Hey dh320 just click on my name Cinematycoon
https://www.ford-trucks.com/forums/member.php?u=326711
and click on download vcard information. (you need to be logged into get it)
I would post it here but I do not want to be overly spammed (like Im not already)
Or post your email in my gallery.
https://www.ford-trucks.com/user_gal...&albumid=21433
Thank you for the complements.
#79
just finished front end 3 inch custom lift in my 79 f150 custom
rear was alot simpler just blocks and new ubolts
lots to do got to finish motor transplant
body job and new paint
box job
also some frame renos a pach here a crossmember there not to bad
also a total break job from lines to linings
well thats what happens when they sit in the bush for about 4 years
still got to love em
box job
#80
#81
#1 Motor mounts #2 different Bell housing since your going from a Big block to a small block possible longer or shorter DS but hopefully you won't have to. If you do go with a 351W make sure your exaust doesn't interfear with your steering on the drivers side. Make sure you have all your brackets for the 351 since your old brackets won't work unless you do some mods to them. Don't forget to make sure your exaust will bolt up your exaust manifold on the 351 if it doesn't you'll need to put new on.
#82
#83
#84
Ford F100/150s rule
Would be more than happy if I can help. I sold my 74 F100 4x4,390 6 years ago, now have a 2001 F250sd, V10, 4x4 4door 6.5 ft bed and still madly in love with it. It's like driving a beamer but with far more fuel.
Ford_Six
Vendor Specials, Discounts, Product Announcements & Group Buys
12-23-2010 07:30 PM
