vibration between 40 and 50 mph - Ford Truck Enthusiasts Forums
Old 04-11-2010, 04:43 AM
USAF FordGuy's Avatar
USAF FordGuy USAF FordGuy is offline
USAF FordGuy is starting off with a positive reputation.
anyone else experience this?? where should i start
Old 04-11-2010, 05:14 AM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
check to see if it's drivetrain related or tire related
at 40-50 mph, turn of the O/D...or shift down into 2nd gear. this will change the RPM range you are in and can help isolate the vibration really quickly
if vibration goes away = driveshaft balance issue or maybe you need some u-joints
if vibration stays constant = tires need balancing
Old 04-11-2010, 09:01 AM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
9.5 times out of 10 it will be a tire balance problem.
Old 04-11-2010, 09:19 PM
trojantiger trojantiger is offline
trojantiger is starting off with a positive reputation.
I had a similar problem. at 60+, my back end felt like it was vibrating. On the highway, I got up to 75 and it was really bad, shaking the steering wheel a lot. Does your vibration only happen at 40-50 mph?
I had recently gotten new tires, so I took them back and said what was up. They removed all the weights and rebalanced them for free. It fixed the problem.
Did your issue start after a recent service or repair? Like new tires?
Old 04-14-2010, 06:41 AM
60DRB's Avatar
60DRB 60DRB is offline
60DRB is gaining momentum as a positive member of FTE.60DRB is gaining momentum as a positive member of FTE.
...if you've been in the mud lately, make sure none stayed on the wheels (check inner areas). It will act like mega balancing weights and do what you're describing.
Old 04-15-2010, 11:36 PM
I checked for mud, happened on my moms explorer once (I luv bein a Ford family lol) it also does it around 93 MPH but mostly noticeable at 40-50, I have the 20"s with street tires on them so Im guessing they are quite sensative to improper balancing, soon as i can ill take it to a tire shop, hopefully the hobby shop on base has their new balancer up n running, it would be cheep or even free that way
Old 04-16-2010, 07:33 AM
shorebird's Avatar
Quote:
Originally Posted by USAF FordGuy View Post
I checked for mud,........... it also does it around 93 MPH but mostly noticeable at 40-50,.........
Tsk, tsk, tsk. I guess you found out about the vibration at 93mph on the racetrack, correct?
Old 04-16-2010, 04:53 PM
Well, I live in the desert. Just as a georaphical reference for ya.... the nearest starbucks is an hour and a half of driving litterally through the desert to get to it, good thing i dont like starbucks! If you're out on that open desert highway, and not being an A hole or doing over 100, cops usually dont mind
Old 07-11-2014, 10:02 PM
abnranger67 abnranger67 is offline
abnranger67 is starting off with a positive reputation.
Hey all, I put some 20's on my 2000 Expedition and my steering vibrates at 50, but stops beyond that. I had the wheels balanced at the place I bought the rims and tires. The guy said one of two of the magnetic weights fell off, so he rebalanced them again. The vibration did not go away, so I went to Midas and had them balanced again. The vibration is still there, it begins at 50, then stabilizes when I get beyond that.
Old 07-12-2014, 05:26 PM
danorules's Avatar
danorules danorules is offline
danorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputation
fyi....You are posting to a 4 year old thread and its in the 04-08 f150 section
But as far as your problems go, it could be a bad tire or bad belt in the tire. Or The tires need to be force balanced. Or it could be a problem in the suspension/ steering
Old 07-13-2014, 06:27 AM
My apologies, did not realize I was posting in the wrong section. I had started to think it might be the tires myself, considering they had been balanced more than once. The other factor being that I got the rims/tires as a deal cause the tires were used. I will buy new tires and see if that fixes the issue. Thanks for the feedback.
Old 07-14-2014, 07:19 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is gaining momentum as a positive member of FTE.1saxman is gaining momentum as a positive member of FTE.
I think I'm reading that the wheels are new. But whether new or used, one or more of them could be bent. When you balance them again, have the tech pay close attention to see if there's any runout in the wheels. The other possibility is that you have bought some bad tires since you said they were used tires. My guess is one or more tires have defects which are giving you the wheel hop. Manufacturing defects or belt separation are the primary causes of bumpy tires.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
Albums 56panelford 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 05-30-2014 12:16 AM
Tags
1997, 40, 4050, expedition, f150, ford, hour, imbalance, miles, mph, shake, shimmy, tire, vibrates, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
