axle tag numbers?
Old 04-10-2010, 09:41 PM
wminmi's Avatar
wminmi
wminmi is offline
axle tag numbers?
Any chance someone here can break down these numbers and see what axle ratio I have with them?
1986 F250/6.9/C6
Axle tag numbers:
V130A
10 10 2 5J09
any help would be appreciated
Old 04-10-2010, 10:08 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,661 Likes on 1,343 Posts
If you unbolt the tag, I bet you can just make out a "4" that has been almost completely punched out for the bolt to go through. I am betting it goes along with the "10 and you have a 4.10 ratio.
Old 04-10-2010, 10:09 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
my guess would be 4:10
on the axle tag,you see the first "10" but look real close up by the bolt and you will probably be able to make out the "4:"
on the door jam-drivers side,whats the axle code there?
edit,
ahh beatin by Dave F
Old 04-11-2010, 07:51 AM
wminmi's Avatar
wminmi
wminmi is offline
thanx guys, I'll see if I can get a closer look at the tag today but I'm betting your correct on the 4.10 as I get up around 55-60mph and the engine is screamin lol
Old 04-11-2010, 08:01 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1986 F250/6.9/C6Axle tag numbers: V130A // 10 10 2 5J09
V130A = Ford WDD (Sterling) 10.25 / 4.10-1 / non Limited Slip.
5J09: Assembled September (J) 9, 1985 (5) / my 41st B/D
Old 04-11-2010, 08:05 AM
starmilt's Avatar
starmilt
starmilt is offline
Number Dummy glad to see you are getting around the site more, sure wish you a full recovery.
Old 04-11-2010, 08:30 AM
wminmi's Avatar
wminmi
wminmi is offline
Thanx fellas
Old 04-11-2010, 10:01 AM
Festus Hagen's Avatar
Festus Hagen
Festus Hagen is offline
Methanoholic
been gone, what happened to ND???
-Enjoy
fh : )_~
Old 04-11-2010, 10:21 AM
NumberDummy
Had a minor stroke on the 16th of March. For several days I had blurred vision in one eye, both arms/hands were numb.
Everything seems to be OK...now. Or as OK as I can be. My wife says I'm as ornery as ever.
Old 04-11-2010, 10:55 AM
Festus Hagen
Methanoholic
Dude, didn't know, So glad it's turning out ok, Been there done that story multiple times, still fighting though! Alls well that ends well is what I keep telling myself!
Keep up that oneryness, thats what keeps it flowing, just don't blow it up again...
-Enjoy
fh : )_~
Old 04-11-2010, 11:34 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
When you look at the numbers the second line gives the relevant information.
The 3 or 4 will be under the bolt head, and if the tag is in good enough shape you should be able to make out either a . or L to the left of the first two numbers.
. indicates open axle, .10 in your case
L indicates limited slip, L10 in your case.
10 would be 4.10 ratio
55 would be 3.55 ratio
Next three numbers 10 2 is 10.25" 97 and older with a 6.5" x 8 bolt circle
10 5 would be a 10.5" after 99 and have 170 mm x 8 bolt circle
1982_f150
03-28-2021 04:58 PM
deezdrama
09-01-2016 08:16 PM
wyazel1
27
07-07-2012 07:19 PM
Tegetus
06-21-2010 08:26 PM
fulltimehiboy
30
05-03-2007 10:47 PM
Quick Reply: axle tag numbers?
