Head Gaskets
I assume this is on the flathead you are building? I agree that coolant quality is important. Is the strength of the studs compromised? Using a good sealant on the threads in the block helps, but you may not want to pull all of the studs. Better now than later?
Aluminum heads get torqued to a lower value than the iron heads, so I'd be inclined to use FelPro composition gaskets, but I have no experience with those heads. On the Ford Barn, lots of guys use copper with lots of CopprKote. I'm not a fan, your deck and heads need to be perfect for that.
1969Highboy
06-08-2009 01:57 AM
johnsf
03-29-2009 03:22 AM
