Compatibility issues of 06 Van V10 into 2000 F350 - Ford Truck Enthusiasts Forums
Old 04-10-2010, 06:44 PM
Mr-Pipeline's Avatar
Mr-Pipeline Mr-Pipeline is offline
Mr-Pipeline has a good reputation on FTE.Mr-Pipeline has a good reputation on FTE.
Anyone have input on compatibility issues installing a 2006 Van V10 into 2000 F350? I know the Vans and Motor<?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com<img src=" /><st1:PersonName>home</st1:PersonName>s continued to receive the 2V V10ís would this <st1:PersonName>work</st1:PersonName> in my 2000 F350? It looks like the air conditioner compressor is located high on the Van instead of low on the F350. What issues would this cause? Any other issues?
Old 04-11-2010, 04:37 PM
Anyone going to bite? I'm looking at a used V10 out of a 2006 E350 Van. It looks like the motor has a duel compressor and duel alternator. I should be able to remove these and have a stock 2V V10? When did they go to drive by wire? Would this be a problem? Could I use my 2000 manifold and throttle body?
Old 04-12-2010, 02:05 AM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
I have no idea, but I didn't want you to feel ignored.
Besides, I may be looking to upgrade to a 3V later, so I will watch your thread.
By the way, I think I have your truck's twin. Harvest Gold?
Old 04-12-2010, 08:06 AM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.
Quote:
Originally Posted by Mr-Pipeline View Post
Anyone going to bit? I'm looking at a used V10 out of a 2006 E350 Van. It looks like the motor has a duel compressor and duel alternator. I should be able to remove these and have a stock 2V V10? When did they go to drive by wire? Would this be a problem? Could I use my 2000 manifold and throttle body?
If your 2000 model is a PI head engine, then you can and will need to use you intake manifold. The '06 E-series is still using the 2V PI engine, and the block is the same externally as the older 2V V10's. So in worst case, you strip it to a bare longblock and reuse all of your external dress items so it'll drop in your truck.
JL
Old 04-12-2010, 10:18 AM
That's what I'm thinking. Even if it's drive by wire I could use my intake and throttle body. I could use my wiring harness and any other items. I sure would like someone to confirm this work before I make the purchase. I never thought about or searched for anything newer then 2004 when searching for engines. I stumble accross this Van motor by accident and now might have the opertunity to upgrade to a newer motor then first thought. Really looking for more feedback before I pull the trigger on this deal.
Old 04-12-2010, 10:36 AM
Externally-ALL 2V blocks are identical. Same with the heads.
There were different front covers,oil pans,intakes,etc used on them,but the dimensions are the same for using your 2000 model parts so they will mate with your truck.
JL
Old 04-14-2010, 07:31 PM
I contacted partsguyed.com (Ed) on the compatibility of the 2006 E-350 V-10 engine fitting in my 2000 V-10 F-350. Ed said, the long block numbers were different and I should look for a different engine. He didnít give specifics on what the changes were. I also spoke with Mike Butler from 5 Star Tuning; he thought the 5 speed transmission on the 06 might be the problem? Anyway, looks like Iíve resolved my original motor oil pressure issue so shouldnít need to perform an engine swap. Iím still interested on what the differences are in the long block numbers if someone knows the answer.
Old 04-14-2010, 11:17 PM
The torqshift has the same bellhousing pattern as the 4R100 or 4R70W. I can assure you that Ford did not change ANYTHING on the Econolines over the years unless it was absolutely mandatory. The 2V engine blocks are all externally the same as for dimensions. Bolt all of your stuff on it,and go.
JL
Old 04-15-2010, 12:00 PM
mwsF250 mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
I'm hoping you won't need it, but if you do, I'm 95% sure you could make this engine fit. As others said, you will need to swap over much of your peripheral stuff... like oil pan, intake, accessory drive.
But all the necessary holes are there.
I put the block from an '06 3V in my '99. The 3V block IS different and has a different part number. The big difference: It has TWO bosses for knock sensors instead of one.
I didn't find that to be too much of a problem.... I flipped a coin and put my single sensor in the right side boss....
And that is the only significant difference I found. The piston crown looked a little different, but I couldn't measure a significant difference in volume. May be a scosche less.
It seems logical Ford would use the same block for both 2V and 3V in '06.
Old 04-15-2010, 08:05 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt Parts Guy Wyatt is offline
Former Vendor
Parts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud of
I just can't confirm it will work. Ford doesn't give me anything but part numbers and they list two different part numbers. So I have to state it wont work. I't might but I can't say it will or will not. :-(
Old 04-15-2010, 08:40 PM
Hi, Ed! It's Martin here... not sure if you remember me, but you scrounged up all the parts I needed when I did my frankenstein combo last year.
Can you check if the long block PN is the same for the '06 E-350 and '06 F-350?
If they are, it would confirm my suspicion that Ford did change the short block for both the 2V and 3V engines in '06. Boosting my confidence to 99%+ that this will work for the OP.
Old 04-15-2010, 10:20 PM
Quote:
You of all people should know how jacked up Ford's parts system is.
JL
Old 04-16-2010, 11:48 AM
Former Vendor
looks like they did'nt put a 6.8L in a van in 06, they did in 05 and 07 and those both have different part numbers then the 06. hmmmm?
Old 04-16-2010, 12:00 PM
Yes,they did put the 6.8L in the E350's in '06. It was a 2V, and was equipped with a torqshift.
Again-you should know how jacked up the parts system is, and how there are gaps and inaccuracies all over the place within it.
JL
Old 04-16-2010, 12:59 PM
Former Vendor
JL
I better tell Ford they forgot to put that info in the parts catalog.
08/02/2004 to 4/18/2005 for the 05 listing in catalog
nothing for the 06 year
10/16/06 to 8/18/2008 for the 07 listing in the catalog
historically anything built after the 9th month is considered the next year make.
2011 6.2L w/54k miles - Head Gasket went and now an Oil Pan GasketÖ WTH! 2Scout 6.2L V8 5 02-04-2017 01:05 PM
Transmission Issues MisterCMK Transit Connect 21 05-22-2016 09:22 AM
1st time trouble starting 95 e350 7.3 low miles 67camaro 1994.5 - 1997 7.3L Power Stroke Diesel 2 11-28-2015 05:19 PM
Texas Jamboree Adds Unlimited Mud Bog Class familyevents Events & Happenings 1 04-14-2008 12:11 PM
jasper engine/EFI changes TIM M. 1987 - 1996 F150 & Larger F-Series Trucks 3 12-17-2005 12:07 PM
Tags
2000, 2006, 373, 54, 98, body, compatibility, f250, f350, fit, ford, throttle, upgrade, v10, van, years
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
