55 F250 brake drum/shoe size issue?
Old 04-10-2010, 05:27 PM
a1tiguy's Avatar
a1tiguy
a1tiguy is offline
After I got my truck back from the shop (front end rebuild, as well as brake job, thru and thru), I just didn't feel like the truck braked as a it should...it's easy when you're new to this hobby to forget what it was like 50 years ago when manual brakes were the norm...but, I was convinced that it just didn't stop like it should...I've mentioned here before that I'm having the heavier work done by a shop, and will tackle some of the simpler issues that I can do with the area I have to devote to it...anyway, I received an interesting email from my mechanic yesterday alluding to 12" vs 12 1/8" brake drums and shoes...he said that a source has told him that there were two sizes at one time, and he's convinced he's got mismatched parts...he's even having custom shoes relined to get to a shoe that conforms to the correct diameter of the drum...anyone ever heard of this before???
Old 04-10-2010, 06:08 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,422 Likes on 1,378 Posts
Nothing in the Ford parts catalog shows anything about a 12 1/8" drum. Only 12" front and rear for '55 F-250.
Old 04-11-2010, 05:01 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
He said that a source has told him that there were two sizes at one time, and he's convinced he's got mismatched parts.
Uh huh...but the source failed to mention what years were affected. Saying at one time is confusing!
He's even having custom shoes relined to get to a shoe that conforms to the correct diameter of the drum...anyone ever heard of this before?
There were two different brake sizes at one time, but this has nothing to do with 1955 F250's, 1956/65 F250's.
It has everything to do with 1966/72 F250 2WD's.
12 1/8" x 2" brakes:
All 1956/65 F250's / All 1966/75 F250 4WD's / Some 1966/72 F250 2WD's (some of these F250 2WD's have 12" x 2 1/2" brakes as it depends on the GVW).
1956/63 F350 (F/R) / 1964/66 F350 front only.
1951/52 F2 / 1953/72 F250 2WD's & 1959/75 F250 4WD's all w/drum brakes: WHATEVER the front brake size is, the rear brakes are the same size and use the exact same brake shoes.
Note: Not relevent, but someone might benefit from this: 1968/72 F250 2WD's were available with optional dual piston caliper front disc brakes. The rear shoes with front discs are 12" x 2 1/2"
Old 04-11-2010, 09:48 AM
a1tiguy's Avatar
a1tiguy
a1tiguy is offline
I was hoping you'd jump in here with part numbers, Bill...it sounds like he's aware of the two brake shoe sizes, but not the reason why...thanks for your help...Terry
Old 05-15-2011, 07:10 AM
55F250's Avatar
55F250
55F250 is offline
1955 F250 brake drums
Where can I find brake drums, I understand that this truck had 12X2" drums.
Can I go with the 12 1/8" X2 if I use 12 1/8" X2 shoes?
Old 05-15-2011, 12:40 PM
teardropty's Avatar
teardropty
teardropty is offline
I have a set of F250 front brake drums off my 54 for sale. New ones are available but very pricing. Let me know if I can help.
Old 05-12-2016, 12:02 PM
ScruffyMcGuffy's Avatar
ScruffyMcGuffy
ScruffyMcGuffy is offline
Need 1954 F250 Rear Brake Drums
Does anyone out there have any or know of anywhere to purchase a pair of F250 Rear Brake Drums?
This is all I need to get my Great Uncle's old pick-up moved to my home.
Thanks,
Old 05-12-2016, 12:43 PM
df85732's Avatar
df85732
df85732 is offline
Thanks,
SruffyMcGuffy - This is old thread and not probably not a good one to look for items. You might try this thead.
https://www.ford-trucks.com/forums/1...and-parts.html
Old 05-12-2016, 12:50 PM
ScruffyMcGuffy
thanks! df85732
Thanks for the Heads up!
Old 05-12-2016, 01:42 PM
NumberDummy
Need 1954 F250 Rear Brake Drums.
TBAA-1126-A .. Rear Brake Drum / Obsolete
1951/52 F2/F3 & F3 Parcel Delivery / 1953/55 F250 & P350 (Parcel Delivery).
No Ford dealer or obsolete parts vendor has any NOS
Old 05-12-2016, 02:26 PM
ScruffyMcGuffy
Understand, but thought someone might have a good old one that still might be usable for sale.
Otherwise what is a replacement for it?
Old 05-12-2016, 07:05 PM
Jules The Great's Avatar
Jules The Great
Jules The Great is offline
Scruffy, Does your truck have the original axle? If someone swapped in a Dana 60 at some point it will be easier to get drums for the rear.
Old 05-12-2016, 08:02 PM
pineconeford's Avatar
pineconeford
pineconeford is online now
Knuckle Bandage Sales Rep
Might have what you need McGuffy - but since you are a new member I can't PM you. Give me a few days to get some pictures together and I'll post them on the for sale link that is noted above.
Tom
madpogue
15
12-16-2017 09:58 AM
SidecarFlip
Transit Connect
10-24-2017 04:15 PM
Code3cody
Large Truck
04-17-2017 09:45 PM
Schuyles
06-27-2016 08:08 AM
Shadow351
1997 - 2003 F150
03-15-2016 05:55 PM
Quick Reply: 55 F250 brake drum/shoe size issue?
