Mobil 1 Synthetic ATF
Old 04-10-2010, 04:47 PM
bpounds's Avatar
bpounds
bpounds is online now
Just used this stuff to change my transfer case fluid. Took 2-1/4 quarts BTW.
Mobil 1 Synthetic Automatic Transmission Fluid (ATF)
Reading the bottle, and the above web page, Mobil says it replaces Mercon, Mercon V, and Mercon LV! It also notes that it is NOT a recommended replacement for Mercon SP.
As we know, Ford says LV now replaces SP. We also know that Mercon V will destroy the servos in the Torqshift. So how can it be that Mobil 1 Synthetic ATF can be a replacement for Mercon V, and Mercon LV, but not be suitable for SP applications?
Just tossing this out for discussion. Your thoughts?
Old 04-10-2010, 05:19 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
MoyockPowerstroke is offline
I too had the same thought...but it didn't stop me from using it in both the transfer case and powersteering box. If you were blind-folded and ask to (smell) tell the difference between Mercon SP and Mobil1 ATF...
you would not have a clue. They smell and look the same, except one bottle is gray and the other is red. Interesting...
Old 04-10-2010, 06:29 PM
69cj's Avatar
69cj
69cj is offline
Same thought here. I would use it in the p.s. pump but would be scared to use it in the tranny. What is the advantage vrs. the risk? I don't personally see one.
Old 04-10-2010, 07:27 PM
powerstroker100's Avatar
powerstroker100
powerstroker100 is offline
my truck is not under warrenty and I have the 6spd manual, I was going to change my tranny fluid this week and replace with the mobil 1 syn atf I think it would be good right?
Old 04-10-2010, 07:33 PM
bpounds's Avatar
bpounds
Just my opinion, but I think it would be perfect for a manual.
Old 04-10-2010, 07:52 PM
gearloose1's Avatar
gearloose1
gearloose1 is offline
We know Ford does not make Mercon....
kawika
49
06-23-2021 11:47 PM
diyster
Escape & Escape Hybrid
06-01-2016 09:54 PM
powerstroker100
10-23-2011 01:19 PM
bismic
11-09-2009 04:19 PM
Rich in CO
23
06-17-2006 02:37 PM
Quick Reply: Mobil 1 Synthetic ATF
