Mobil 1 Synthetic ATF - Ford Truck Enthusiasts Forums
Old 04-10-2010, 05:47 PM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Just used this stuff to change my transfer case fluid. Took 2-1/4 quarts BTW.
Mobil 1 Synthetic Automatic Transmission Fluid (ATF)
Reading the bottle, and the above web page, Mobil says it replaces Mercon, Mercon V, and Mercon LV! It also notes that it is NOT a recommended replacement for Mercon SP.
As we know, Ford says LV now replaces SP. We also know that Mercon V will destroy the servos in the Torqshift. So how can it be that Mobil 1 Synthetic ATF can be a replacement for Mercon V, and Mercon LV, but not be suitable for SP applications?
Just tossing this out for discussion. Your thoughts?
Old 04-10-2010, 06:19 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke MoyockPowerstroke is offline
MoyockPowerstroke has a good reputation on FTE.MoyockPowerstroke has a good reputation on FTE.MoyockPowerstroke has a good reputation on FTE.
I too had the same thought...but it didn't stop me from using it in both the transfer case and powersteering box. If you were blind-folded and ask to (smell) tell the difference between Mercon SP and Mobil1 ATF...
you would not have a clue. They smell and look the same, except one bottle is gray and the other is red. Interesting...
Old 04-10-2010, 07:29 PM
69cj's Avatar
69cj 69cj is online now
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Same thought here. I would use it in the p.s. pump but would be scared to use it in the tranny. What is the advantage vrs. the risk? I don't personally see one.
Old 04-10-2010, 08:27 PM
powerstroker100 powerstroker100 is offline
powerstroker100 has a good reputation on FTE.powerstroker100 has a good reputation on FTE.powerstroker100 has a good reputation on FTE.
my truck is not under warrenty and I have the 6spd manual, I was going to change my tranny fluid this week and replace with the mobil 1 syn atf I think it would be good right?
Old 04-10-2010, 08:33 PM
bpounds's Avatar
2 bit Californian
Just my opinion, but I think it would be perfect for a manual.
Old 04-10-2010, 08:52 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
We know Ford does not make Mercon....
Is Valvoline MaxLife ATF okay for 2003 Ford Escape V6? diyster Escape & Escape Hybrid 12 06-01-2016 10:54 PM
Mobil-1 ATF for 4R100 kawika 1999 - 2003 7.3L Power Stroke Diesel 28 03-02-2016 09:39 PM
Valvoline Maxlife ATF Bullitt390 6.0L Power Stroke Diesel 21 02-24-2015 02:26 AM
ZF6 fluid (Mobil1?) carlsson 1999 - 2003 7.3L Power Stroke Diesel 2 02-06-2008 10:21 PM
Transfer Case Fluid Rich in CO 1999 - 2003 7.3L Power Stroke Diesel 23 06-17-2006 03:37 PM
Tags
atf, automatic, buy, change, diesel, fluid, ford, lv, mercon, mobil, recommended, reviews, sp, synthetic, transmission, versus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
