1992 Explorer 4x4 Front wheel bearing torque ? - Ford Truck Enthusiasts Forums
Old 04-10-2010, 05:08 PM
zzrich zzrich is offline
zzrich is starting off with a positive reputation.
I am working on my explorer again. Its a 4x4. Replaced rotors, calipers, and pads. The one problem I have always had is getting the correct torque spec for the front wheel bearing lock nut. I know back in the old days you would torque the wheel bearing down to set the bearings, thing then back the nut off a bit and stick in a cotter pin. I have even looked in manuals and the torque procedure was always vague. If someone could clear this up it would be a great help !
Old 04-10-2010, 11:02 PM
mrshorty mrshorty is offline
mrshorty is gaining momentum as a positive member of FTE.
Same basic procedure, only instead of a cotter pin, there's a locking key (auto hub) or locking ring (manual hub). If you want to put numbers to it, haynes/Chiltons specify 30-40 ft lbs for seating the bearings, and about 16 inch lbs for the final torque.
Old 04-11-2010, 04:27 PM
Thanks Mr. Shorty. I have them FAR too tight then. Thats great knowledge, you probably just saved me a set of wheel bearings !
Torque specs remhaust Ranger & B-Series 1 11-01-2016 12:40 PM
wheel bearing and hub help waylen89 1987 - 1996 F150 & Larger F-Series Trucks 12 09-15-2016 10:50 PM
Spindle Nut Size? wiskeyVI 1968-2013 Full Size Vans 8 06-20-2015 07:54 AM
wheel bearing adjustment ac700wildcat 1987 - 1996 F150 & Larger F-Series Trucks 4 04-28-2010 05:24 AM
2000 X front wheel bearing ? TransplantX Excursion - King of SUVs 3 12-30-2009 07:55 PM
Tags
1992, 2001, 4x4, 92, bearing, bearings, explorer, f150, f250, ford, front, hub, specs, torque, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
