A Loose Bolt Can Ruin Your Day!
on
Two weekends ago I went to hook up up my 12' utility trailer and after doing so TRIED to take off. The truck slipped a little, but started to move. After a little more throttle, it was underway. As I moved out onto the road in front of my house, my trans started slipping worse and would barely go. I backed back into the driveway, as reverse worked great. I unhooked my truck, found another I could borrow, pulled mine away from the trailer, and went about my business since I was already running late. The next day I pulled my truck back over to the garage driveway and backed it into my garage. I did my research into why this could have happened, hoping for a simple solution. That Monday night, I pulled the trans pan, valve bodies, and separator plate to discover my suspicions were correct in that the forward clutch feed bolt had backed loose and bled off forward pressure. I am going to try and document my current rebuild and upgrades that should eliminate any further problems and explain why this happened in the first place.
Here is an album 4R100 Rebuild and Upgrades pictures by mueckster - Photobucket , I started on Photobucket, to show my upgrades and explain some things I learned about the rebuild process and hopefully help others along the way. Any questions, comments, or pics (more on the way) you'd like to see, let me know. I am in the process of doing this right now. I had to gather up all the parts over the last two weeks and work has kept me from getting to it until now. Thank God for friends. I have a truck that I can use for as long as needed. I called in a few markers.
on
No major damage, Pete. I could have basically put in new bolts, retorqued them, and been on my way. The only thing was not knowing the condition of the forward clutches due to the slipping. I figured "better safe than sorry" and tore it down. I'm glad I did, as that would have only been a temporary fix due to the finding of the "walking" center support and not wanting to take chances of failure on a long trip from home.
on
"Hindsight is 20/20." I wish I would have learned of some of these upgrades when I was doing the first rebuild about 37k miles ago. Would have saved me some grief now. I just want to pass on what I've learned to the Brotherhood. I will be doing a few other small mods to the valve bodies, too.
Roland, this is awesome stuff. Your documentation is great and so are the explanations. I am sure the entire Brotherhood would be very interested in a detailed write up of your thoughts and experiences with this. I consider myself very mechanical and would be willing to do a transmission tear down if mine were to go.
That is the one thing on my truck that I cannot afford to have break until I get on my feet here in Alaska.
