A Loose Bolt Can Ruin Your Day!
#32
on
Wish I had shown my upgrades to the accumulator and main vb's. I guess I could scan the pics from the instruction sheets and add them to the album, if y'all would like to see them.
#33
I can't take all the credit, Mike. I was talking with one of the trans techs at Suncoast and he gave me a few pointers. Nice fella. He told me to let him know how it all turned out. I guess I owe him a phone call and a big "Thanks". I just keep learning more new things all the time.
#35
on
Darrell, I would love to talk trans with you again. All the mods done to the pump are included in the HD2 and Tugger kits. I just added the "on-off" type lock up conversion valve for the TC lock up.
#37
#39
on
I think the pump mods are worth doing. Electronic control of pressures is limited to line pressure controlled by the EPC solenoid. Torque converter lock up pressure is controlled by a separate regulator valve in the pump. IIRC, lock up point and pulse width of the TCC solenoid is the only electronic controls of the TC that I'm aware of.
#40
Roland I was looking at your pics and seen the note about the steel pistons and aluminum ones.I have a tugger HD2 kit and I will change all my pistons to steel when I do the valve body.
Were did you get the other two steel pistons from?
I picked a trans real cheap so I can learn on it first before I tear into mine.If the pump looks good I will do thoses mods also.That way I can pull mine and just swap out the parts and not have alot of down time.
#41
on
#43
Well I have my steel valves on the way and will be ordering the sonnax valev mod also.
Sonnax Transmission, Torque Converter, Performance, Driveline Parts :: High Performance Transmission :: 36947-09K :: Part Summary
Dumb question is the pump assem the from a 99 trans to a 01 the same?
If it is I will be able to mod the pump from the 99 with my HD2 kit and just swap out the pumps.RIGHT?
I would like to be able to go through the hole trans,but time and funds are not on my side right now.
#45
