Changing Fuel Filters on 6.0L - Ford Truck Enthusiasts Forums
Old 04-10-2010, 02:14 PM
blowhole's Avatar
blowhole blowhole is offline
blowhole is starting off with a positive reputation.
Went out this morning to change the fuel filters on my 6.0L. Bought the prescribed Motorcraft filters, all ready to go.
I read up on how to do the change, all the manuals, online, etc. Seemed easy enough.
First, got underneath the truck, and I do not see the water release valve. No lever to release the excess water!
Second, changed the filter engine-side without a problem. New gasket, new filter, fine.
Third, go back underneath to change the larger filter at the fuel pump and discover that there is no way on earth that I can get the new filter into a position to replace the old one, much less get the old one out. The front drive shaft (4x4) and the frame create a space much too small to fit the new filter in. And the brake, a/c, and fuel lines running along the frame prevent me from accessing the front of the pump at the filter housing from any other direction. WTH?
Now, I did not have time to lift the Ex and put her on stands to see if a sagging front end would create more space between the front drive-shaft and the frame. But other than that, I have no idea how to get to the filter-side of the pump.
I will try and take a pic later to show you. But until then, anybody else have a smart answer to this??
Please advise and thanks in advance.
EDIT TO ORIGINAL POST TO INCLUDE PICS OF PROBLEM:
Old 04-10-2010, 02:22 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
Look at this picture....
Service Points - HFCM and Fuel Filters
See the flat brass plug? That drains the water. Then for the future, get one of these...
HFCM Drain Plug
Not sure what it looks like under your EX, my truck is tight also, just used short strokes and it worked, some have used an extension to move the wrench further back. Haven't tried that yet. Next fuel filter change will be different. And no, I didn't take a diesel bath. Used rubber gloves also.
Check Tech folder for more info.
Old 04-10-2010, 08:05 PM
sandmanf250 sandmanf250 is offline
sandmanf250 is gaining momentum as a positive member of FTE.
drop the the front driveshaft.
Old 04-10-2010, 08:38 PM
blowhole's Avatar
HFCM Drain Plug
Reps given for that link to the drain plug - that is perfect. Also, thank you for the pic of the stock drain bolt. Why Ford did not update their user manual to reflect a different method for draining the water is beyond me.
Old 04-10-2010, 08:39 PM
blowhole's Avatar
Quote:
This could be a possibility. But, always a big but, how difficult is it drop the driveshaft? How time consuming? Got a link to the process?
Old 04-10-2010, 10:12 PM
fordtech08's Avatar
fordtech08 fordtech08 is offline
fordtech08 is gaining momentum as a positive member of FTE.
I change those filters on drive on racks all the time, or on the floor, use an extension from behind the trans case makes life simple, and no I have yet to drop the driveshaft
Old 04-10-2010, 10:14 PM
dschuffert's Avatar
dschuffert dschuffert is offline
dschuffert is gaining momentum as a positive member of FTE.dschuffert is gaining momentum as a positive member of FTE.
I use an oil filter strap. Same here, no need to drop the driveshaft.
Old 04-10-2010, 10:22 PM
DPorter DPorter is offline
DPorter is gaining momentum as a positive member of FTE.
So do I. The oil filter wrench.
Old 04-10-2010, 10:43 PM
blowhole's Avatar
Guys, thanks for the responses. Maybe I didn't adequately explain myself. Let me try again:
I don't have a problem getting the filter cap off, I can unscrew the cap.
The issue is getting the old filter out of the pump and the new filter back into pump. The front drive shaft (4x4) and the frame create a space much too small to fit the new filter in. And the brake, a/c, and fuel lines running along the frame prevent me from accessing the front of the pump at the filter housing from any other direction.
I will take a pic and post, hopefully I will get a chance tomorrow.
Old 04-10-2010, 10:47 PM
fordtech08's Avatar
there is room to do it with out takeing anything else apart try putting the filter and cap up there as two pieces instead of together
Old 04-10-2010, 10:50 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
after unscrewing the cap, pull it all out just far enough to pull the cap off of the filter. Take the cap from the filter area and set it aside (clean location). You should then have enough room to remove the filter element.
Do you insert the new filter partway into the housing, then bring the cap into position and snap the filter into the cap before screwing it on?
Edit - nice post fordtech08 (and a whole lot fewer words than me)
Old 04-12-2010, 03:25 PM
blowhole's Avatar
Here are some pics of my predicament:
You will notice that the space between the front driveshaft and the bottom of the frame prevent me from inserting the new filter into the space that leads into the pump. I have ruined this filter trying to find a reasonable place to put insert the thing.
Let me know what you think. Sorry, just cellphone quality pics.
Old 04-12-2010, 03:48 PM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
Try going over the top of the drive shaft.
Old 04-12-2010, 04:01 PM
blowhole's Avatar
Quote:
No, not even close! Not unless I jacked up the front of the truck so much that the front-end sagged enough to give me space to insert the filter?!?!?! But I don't know if that is possible, I only have a standard jack.
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
If you jack up the car at the frame (letting the diff drop) it would create more room beside the filter.
Then go way down away from the filter where there is a bigger opening (because the drive shaft is tilted).
Slide out the old filter that way, then get the new one in the same way, while keeping it clean (maybe wrap it up?)
Tricky... I don't envy you.
Mine is on the outside of the frame rail and is the vertical type...
New Radio Install Pics javieljb 2004 - 2008 F150 22 03-30-2011 05:05 PM
Rusted out Frame, 2001 ext cab, any ideas? powersmoked Ranger & B-Series 6 02-09-2011 12:36 PM
Love my new dash cover! ospreyguy 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 18 12-13-2010 05:40 PM
Exclusive photos of 2011 Super Duty launch event BigF350 1999 to 2016 Super Duty 20 03-17-2010 11:52 AM
Stripped Flywheel, Replace? bkgeig 1999 - 2003 7.3L Power Stroke Diesel 4 12-03-2009 06:39 PM
Tags
2003, 60, 60l, change, changing, diesel, f250, f350, filter, filters, ford, fuel, liter, powerstroke, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
