Just hooked up AE and have codes P1876, P1832, input needed
Old 04-09-2010, 10:07 PM
SilverBullet131313's Avatar
SilverBullet131313
SilverBullet131313 is offline
Just plugged in AE tonite and pulled codes and P1876 and P1832 came up. I cleared the codes and drove around the block and engaged 4 wheel drive and then disengaged it to see if they came back and sure enough they did. So what do these mean or what to look at to replace?
My 4wd seems to work fine, the lights light up with no issues on the dash, so switch seems to work, the front ds spins when i enegage 4 high and you can feel the hubs pop in when switched to 4 high,...everything seems fine yet the codes are there. I did not try 4low though.
Only thing this past winter i noticed one time is when we had a ton of snow up here, i switched a few times in and out of 4 high and 4 low when stuck...and noticed a burning smell. But i used 4wd after that and no issues.
So any ideas or input would be appreciated.
Old 04-14-2010, 06:45 PM
SilverBullet131313
Just to update....just driving around normal and never engaging 4wd i still flagged these codes. So anyone have any input or a direction to take?
Old 10-07-2010, 10:47 PM
biostroker's Avatar
biostroker
biostroker is offline
Did you figure this out? I am having the same codes, but everything seems to be working just fine.
Old 10-07-2010, 11:59 PM
Riffraff Diesel's Avatar
Riffraff Diesel
Riffraff Diesel is online now
PREMIUM SPONSOR
For some reason those codes seem to pop up every once in a while. If you aren't having issues I wouldn't worry about them. You will also get a KAM Error code, and ICP code sometimes.
Old 07-08-2013, 10:05 AM
bbender85's Avatar
bbender85
bbender85 is offline
digging deep in the vault here, but i have AE on hand right now and have these codes as well. anyone have any more input on these two codes? clay makes it sound like they aren't a big deal, but the tinkerer in me has to ask.
Jesser02EX
09-16-2016 09:31 AM
Rusty Axlerod
11-05-2015 04:29 PM
emac396
1999 to 2016 Super Duty
04-07-2015 11:13 AM
captbad
02-19-2012 07:33 PM
Quick Reply: Just hooked up AE and have codes P1876, P1832, input needed
