Heater Core, Inlet/Outlet? - Ford Truck Enthusiasts Forums
Old 04-09-2010, 01:50 PM
deyomatic deyomatic is offline
deyomatic is starting off with a positive reputation.
I just stuck a 350 in my '60 F100 and up until now, have had the heater fitting in the manifold looped back into the fitting on the water pump. It's time to hook it all back up and I'm wondering if the heater core inlet and outlet are specific (directional) or if it doesn't matter which hose goes onto which fitting.
I wouldn't think it matters but I don't want to find out the hard way.
Thanks.
Old 04-09-2010, 01:58 PM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
Well, it won't blow anything up, but hose placement will dictate how well you heater works and wear on the core.
The inlet nipple is the lower one and the exit nipple is the upper. This forces the coolant flow to fight gravity to flow and forces any air out of the core.
The heater inlet (lower) is supplied by the outlet on the intake manifold, and the heater core outlet (upper) routes back to the water pump stem.
Old 04-09-2010, 05:31 PM
Baxtjh Baxtjh is offline
Baxtjh is starting off with a positive reputation.
Thanks Julie...
Now I know I hooked mine up bassackwards in my 53.' Oh well, sumthin else to change.
Howie
Old 04-09-2010, 06:15 PM
Wow, now I had THAT all bassackwards, too. I assumed the pump fitting would have been the pressure side supplying flow to the core.
Thanks AGAIN, Julie!
Old 04-10-2010, 01:51 AM
Nope, the separate water pump tube is a bypass of the thermostat that allows coolant to flow out of the manifold through the heater and get recirculated into the engine when the thermostat is still closed keeping coolant stationary in the engine - warming up until it reaches operating temperature!
So you get hot water right off the engine to the heater and then it gets sent right back into the engine to warm up some more.
Thus you'll get hot coolant to the heater core long before the radiator ever sees any.
Heater Core Hoses: Inlet x Outlet/Return celsoglima Ranger & B-Series 7 12-16-2016 10:06 AM
Heater hose question Renegade3064 1999 to 2016 Super Duty 5 03-07-2016 07:26 PM
98 Expedition Heat Issue HMAN1055 Expedition & Navigator 13 12-15-2014 12:44 PM
heater hose confirmation Green Griffin 420 1987 - 1996 F150 & Larger F-Series Trucks 4 12-30-2013 06:55 PM
What's the direction of flow through heater core? jtharvey 1999 - 2003 7.3L Power Stroke Diesel 5 08-06-2008 12:07 AM
Tags
antique, core, f150, find, flow, ford, heater, hose, inlet, inletoutlet, matter, outlet, pump, tube, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
