ding noise when door is open - Ford Truck Enthusiasts Forums
Old 04-09-2010, 11:35 AM
highteckredneck's Avatar
highteckredneck highteckredneck is offline
highteckredneck is gaining momentum as a positive member of FTE.
i was wondering if anybody has turned that ding noise off when the door is open? it is really annoying when your listining to the radio and all you hear is that ding noise. so if you have or know how to turn it off, please let me know.
Old 04-09-2010, 12:42 PM
93 mix 'n match's Avatar
93 mix 'n match 93 mix 'n match is offline
93 mix 'n match is gaining momentum as a positive member of FTE.93 mix 'n match is gaining momentum as a positive member of FTE.
Quote:
i believe the speaker is under the drivers seat. only bad part about it is if you forget to turn your headlights off, theres no warning ding.
Key stuck in lock cylinder - will this drain battery? DoofusOfTheDay 1987 - 1996 F150 & Larger F-Series Trucks 4 08-17-2014 05:35 AM
ARG! DING DING DING Again. :( 93nighthawk Aerostar 2 06-19-2009 03:10 PM
Some sort of buzzer DieselBeast01 1999 - 2003 7.3L Power Stroke Diesel 10 07-08-2008 10:03 AM
Any way to disable that anoying DING? jimlj 1999 to 2016 Super Duty 16 08-11-2006 08:16 PM
Seat belt ding Diesel Smoker 6.0L Power Stroke Diesel 8 09-10-2003 11:43 PM
Tags
150, 1997, 97, car, ding, dings, door, driver, f150, ford, makes, noise, open, opening, short
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
