2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Replacing front brake pads
Old 04-18-2010, 02:22 PM
00excursion's Avatar
00excursion
00excursion is offline
Getting ready to swap out the pads on my 07, are there any special tools or other things I need to keep in mind before getting started?
Old 04-19-2010, 10:59 AM
berry1234's Avatar
berry1234
berry1234 is offline
Yeah, get the rotors turned.
Old 04-20-2010, 12:18 PM
gddyup's Avatar
gddyup
gddyup is offline
Or better yet, bite the bullet and pick up a set of front rotors to go with those new pads. Making front rotors thinner on a 6,000 pound vehicle by cutting them down is iffy at best. If you don't have a brake pulsation right now, you probably will develop one after slicing up your rotors.
Replacing pads and rotors together as a set is the best way to do it.
Old 04-20-2010, 12:28 PM
berry1234's Avatar
berry1234
While I agree it's the best, the rotors are designed to have enough thickness to be resurfaced before you get below the minimal thickness-as long as you don't cross this, your ok. Whatever you do, you need a clean surface for the new pads to deposit some material onto the rotor evenly. The pulsation is caused from uneven material transfer which causes bumps or hills and valleys of pad material-this translates into vibration when braking.
headleyj
1999 to 2016 Super Duty
08-01-2014 09:50 AM
gascan
6.7L Power Stroke Diesel
05-28-2014 04:02 PM
Chris6603
10-15-2013 03:00 PM
Quick Reply: Replacing front brake pads
