hot rod 66 f600?
hot rod 66 f600?
has anyone ever hot rodded these older heavy trucks? i'd love to see pics of one of these old girls hot rodded. i've got a 66 f600 and my step father wants to scrap her but i just love the look of this old girl. so im wondering if anyone has every built a hot rod out of one of these. i'd love to see one lowered down a bit maybe ridding on some newer aluminum rims.
The following users liked this post:
if anyone has any good pics of one of these ol girls all done up i'd love to see it. im happy it does have 20" rims so i could use modern day suv tires on it to help get her down to earth. talked to my step father about trading some work for her and he doesnt care but worrys about it being a money pit...i am now looking into the possiblity of how to lower the nose. trying to figure out how to drop the front beam down. i could ditch a couple of the nine leaves i guess.
Removing some leafs would sure bring it down...and soften the ride up quite a bit. If you are just wanting to have a rig to ride around in, the softer springs will not be a problem.
You might could even get away with pulling more leafs than that...just don't go crazy and pull all of them. You might try pulling every other and see what happens.
ROb
ROb
Warrenty Plate VIN & codes as pictured in post # 10.
F60CK861620 / 156 / M / F602 / 481 / A / F7C / 20000 / 164 / 3800 / 521407
F60 = F600 2WD (gas)
C = 330 2V Medium Duty
K = Kansas City Assembly Plant
861620 = 1966, assembled in May 1966
156" Wheelbase
M = Wimbledon White
F602 = F600 2WD (gas) / 20,000 lbs. GVWR
481: Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl / 81 = 81A Standard Cab
A = New Process 435 4 Speed Manual Transmission.
F7C: F7 = Eaton 2 Speed Rear Axle / 5.83/8.11-1 / 15,000 lb. Rear Axle Capacity // C = Ford Rockwell-Timken Front Axle / 6,000 lb. Front Axle Capacity
20,000 lbs. Gross Vehicle Weight Rating
164 net HP @ 3800 RPM
521407: 52 = Des Moines IA Ford District Sales Office, where the original selling dealer ordered the truck from. / 1407 = Domestic Special Order number.
I doubt you will be able to use modern 20" SUV radials with this truck's split rims. They will not be compatible.
Trying to find a tire shop in today's world that will dismount the tires from the split rims, will not be EZ.
While others might like to see you make this monster into a hot rod, they aren't doing the work...or paying the bills.
I agree with your step father...this is a 10,000 lb. plus...money pit.
156" Wheelbase
M = Wimbledon White
yeah it could be a money pit...hard to say. im not worried about how much labor may be involved. im doing a full on resto on my 73 highboy, the only part i need to farm out is welding the thin metal. we have 3 large welders on site. i can fab cut and modify just about anything. i didnt know these are those much dreaded split rim. we have 2 large tire machines for mounting semi and car wheels. i'd have to see if my step father is good at these type of rims. he's been doing tire work on large trucks for several years.
number dummy thanks for the break down. thats awsome to know about that. i do have a couple options i guess. one, i could swap the front and rear axles to a newer dulley set. or two, i could swap the body onto the dulleys frame. not sure of what year it is as its just a chassis with a 6.9 diesel. or i could slam the body onto the 76 pete frame with a 3406 cat motor...LOL granted i'd be driving from the bed...lol yeah i plan on just driving the truck around for fun. if i need to move anything super heavy, we've got 3 semi's waiting...i highly doubt their is replacement wheels with that massive 6 x 8.75 bolt pattern.
