truck battery not charging? - Ford Truck Enthusiasts Forums
Old 04-07-2010, 08:45 PM
bluescrew's Avatar
bluescrew bluescrew is offline
bluescrew is gaining momentum as a positive member of FTE.
tested from back of alternator to ground when running, 14 volts. tested batteries when not running, 12V. when i try to start it sounds like its got a very weak battery.. could this be the starter? anyone know whats going on?
this first happened when i was out fishing went to start my truck and i had to get a jump to start my truck.
did play music without truck running for about an hour....
anyone??/
Old 04-07-2010, 08:56 PM
bluescrew's Avatar
my prob: i cant start truck without jumping it
Old 04-07-2010, 08:58 PM
DemonRace6's Avatar
DemonRace6 DemonRace6 is offline
Hi!
DemonRace6 has a very good reputation on FTE.DemonRace6 has a very good reputation on FTE.DemonRace6 has a very good reputation on FTE.DemonRace6 has a very good reputation on FTE.
anyone??/
Do you need a jump every time? Or will it start right up after driving for a while?
Old 04-07-2010, 08:59 PM
damicofuel's Avatar
damicofuel damicofuel is offline
damicofuel is gaining momentum as a positive member of FTE.
aer cables clean and tight? that was a problem I had
Old 04-07-2010, 09:05 PM
bluescrew's Avatar
yep just sanded them all down
i actually just got it started on its own without jumping it, after running it jumped for 10 mins.
i charged my batterys all day yesterday then went to start this morning and it would not start.
what else can i test?
14v off alternator while running
Old 04-07-2010, 09:14 PM
damicofuel's Avatar
unhook batteries and put a load test on them, may have a bad cell
Old 04-07-2010, 09:29 PM
bluescrew's Avatar
how do i do a load test? i have a multimeter
Old 04-07-2010, 09:31 PM
CPUNeck's Avatar
CPUNeck CPUNeck is offline
CPUNeck has a very good reputation on FTE.CPUNeck has a very good reputation on FTE.CPUNeck has a very good reputation on FTE.CPUNeck has a very good reputation on FTE.
In the morning, before you do anything, open the hood of the truck and feel your alternator. Is it the same temperature as the surrounding metal stuff... or is it "warm" (feel all around it)
How many volts are you reading at the + post on the battery? (grounded to the SAME place)
Is the acid level good on all the cells. (If not, I recommend purchasing some battery acid at the parts store to top them off. I know it's common practice to add water, but that isn't the best practice. The acid is cheap) Are the batteries "swollen?" Have you noticed dampness on the tops of the batteries, or was there visible corrosion before you cleaned them? Check the main engine grounds at the front of the engine. (especially on the passenger side) To find them, just follow the - wire. Just a couple of places to start.
Old 04-07-2010, 09:37 PM
DemonRace6's Avatar
Hi!
Quote:
What would a warm alternator mean? I ask because I think I may have had this problem with my old alternator.
Old 04-07-2010, 09:41 PM
bluescrew's Avatar
ok its running right now
got 13 v off alternator and positive side of battery
Old 04-07-2010, 09:55 PM
CPUNeck's Avatar
Talking electricity, anytime there is "heat" energy is being "used" (like a light bulb) If you Alt. is warm, your "leaking" electricity... probably from one of the diodes on the rectifier/regulator assembly. Not field serviceable, probably time for an alternator. At least you could pull the Alt. off and carry it to O'Rileys or Napa for testing to confirm. (I don't use stores that start with an "A")
When you say 13v is that 13.00v? If so, that's to low (unless you have a bad cell in one of your batteries.) 13.9v OK.
Old 04-07-2010, 11:54 PM
bluescrew's Avatar
excellent information!!! will check both exact voltage and temp of alt in the morning and get back to you
thank you very much!
Old 04-08-2010, 01:15 AM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
I had same issue. Cleaned cables and had alt tested 3 times in a row to make sure (changed terminals and unplugged wireharness to tester every time to see if it was a fluke).
I replaced he batterys and same issue starting.
Changed starter and fixed the issue. Starter is quick and easy to swap. It took 30 min in the parkinglot. (did all this in parts store parkinglot...I even replaced the idler pullys)
Old 04-08-2010, 07:27 AM
fifthwheel01 fifthwheel01 is offline
fifthwheel01 is starting off with a positive reputation.
I've been fiddling with the same problem, slow crank (cold) for three or four seconds then click-click nothing. Put the charger on (6amp) 30 minutes cranks right up and cranks all day and tomorrow just fine. If it sits 36 hrs or so, back to crank-crank -click -click.
Hpop level ok, batteries 12.v cold indv., running 14.6v.
In last month replaced GPR, all GP's, positive battery cable (thats alotta cable) and one neg.terminal clamp. Cleaned up all the rest. Finished day before yesterday.
49* cranked up just a wee bit slow but fired up. guess I need th starter draw checked.
Old 04-08-2010, 07:37 AM
farmdad's Avatar
farmdad farmdad is offline
farmdad has a great reputation on FTE.farmdad has a great reputation on FTE.farmdad has a great reputation on FTE.farmdad has a great reputation on FTE.farmdad has a great reputation on FTE.
Since this happened to me, I'll pass it on. Check the positive cable end at the starter. Does it look like it has been hot or burned? I had put on a new starter which helped for a few weeks when the problem returned. When I was replacing the starter again, the cable end fell off. Took the cable to the parts store to have a new end put on and the truck has been starting fine ever since. Once the copper has been overheated, it seems to not have the continuity that it needs to work properly. Just another place to look.
Battery light on after new alternator and batteries frdf250 6.0L Power Stroke Diesel 14 02-08-2017 06:19 PM
1994 F-350 XLT Battery Light Stays On Leftyizme Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 05-01-2014 10:34 PM
Anyone know anything about Exide batteries? bigunit54 2004 - 2008 F150 18 12-06-2011 11:10 PM
Battery Voltage caere 6.0L Power Stroke Diesel 8 07-14-2010 11:48 PM
97 Alternator?? SHADES 1997-2006 Expedition & Navigator 5 09-27-2005 12:26 PM
Tags
1999, 73l, battery, charging, clean, cluster, diesel, diode, f250, f350, ford, number, part, posts, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
