Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > North Carolina Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
North Carolina Chapter Join Chapter, Leader:ncheavymetal
  #1 (permalink)
Old 04-07-2010, 07:11 PM
Wicked Endings's Avatar
Wicked Endings Wicked Endings is offline
1985 Ford F-150
Wicked Endings is gaining momentum as a positive member of FTE.
NC Vehicle Inspection Requirements
Hello! I've got an '85 F150, and right now it has two problems that I believe I need to fix so it will pass inspection.
Backup lights
License Plate lights
Does anyone know if Backup lights are mandatory in the state of NC? Well, do they have to work so I can pass inspection?
__________________
Paul
"Experience is the name everyone gives to their mistakes"
http://thefallofdemocracy.tripod.com/fallofdemocracy
1985 Ford F150//4.9 Straight Six Engine//Automatic C4 Transmission
  #2 (permalink)
Old 04-07-2010, 08:26 PM
fuzzy1626's Avatar
fuzzy1626 fuzzy1626 is offline
Garage is empty, add now
fuzzy1626 is starting off with a positive reputation.
All I can tell you is my F250 had it's inspection on 3/02/10 and the print out they gave me did not list backup lights. It had headlights,parking lights,tail lights, beam indicator light/switch,license plate light,stop light and directional signals.
__________________
Tony 1994 F250 XLT ext. cab,long bed,7.3 IDI factory turbo,4x4,manual hubs,E4OD,4.10 gears, K&N air filter,Hayden 679 trans. cooler,PSD oil filter,coolant filter and vac. operated heater shut off valve, manual glowplugs,Autometer water temp.,trans. temp., and pyro in three guage pillar pod, Autometer mechanical oil pressure under dash with twin vac/boost guages,TruxPort tonneau cover,straight piped,189,000 miles and counting. 88 Ranger 2.0, 5 speed,147,000 mi.,bought new.NC Chapter Member,IUE Retired, NRA Life Member,USMC.
  #3 (permalink)
Old 04-07-2010, 08:30 PM
1985 Ford F-150
Backup lights probably go under tail lights..
__________________
Paul
  #4 (permalink)
Old 04-07-2010, 09:34 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
The only way to know is to take it and see if they fail the truck. Inspectors usually don't look at older vehicles very closely.
__________________
Eric
'87 F150 302 ZF 5 speed 4x2
  #5 (permalink)
Old 04-10-2010, 06:46 PM
schlepprock250's Avatar
schlepprock250 schlepprock250 is offline
Guns Dont Kill People..
1999 Ford F-250
schlepprock250 has a great reputation on FTE.schlepprock250 has a great reputation on FTE.schlepprock250 has a great reputation on FTE.schlepprock250 has a great reputation on FTE.
fordf250guy
I don't think back-up lights are required,I've never been told to put it in reverse for an inspection.
__________________
Phil Late'99 F-250 SuperDuty 4x4 SB CC 7.3 Magnaflow4"TurboBack SS Exhaust(muffled) DP-Tuner:No Start,Stock,High Idle,60Tow,Decel,80Tow,80Econo,120Race,Lope Idle AIH Delete OBA AutoMeter UltraLite Series Gauges Boost/Trans/Pyro Dieselsite Billet T-Stat Housing(195 Stat) BTS ValveBody Spicer/Custom Driveline(front & rear) ATS Housing HPX FRX Wrapped 6637 6.0 Trans.cooler Bellowed Up Pipes GPR LED Tank Mods Pre Pump Filter Riffraff I/C Boots W/Riffraff Plenum Inserts.50 mod Warn Hubs Prodigy P2 B.E.S.T. Map PAA Member # 34
  #6 (permalink)
Old 04-10-2010, 07:52 PM
06silvercrew's Avatar
06silvercrew 06silvercrew is offline
06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.
As an inspector, I can tell you they are both reqired. Me personally if one of each works (one reverse and one tag) I will pass it. If you want to get technical about it, even if NC inspection doesnt say an item specifically must work, if its on the vehicle, it is supposed to work. But Im flexible lol.
__________________
-Scott
SOLD 2-28-11.....
'06 F250 CC/SB PSD. 2'' lift, Bilstein 5100's, Dual stabilizers, 20'' Harley wheels, 35-12.50 MT ATZ's, 08 Mirrors, ARP studs, EGR delete, 4'' MBRP, X3 with custom tunes, Full gauges, scangauge II, Coolant filter, Red top Optimas, DC 185a alt,
  #7 (permalink)
Old 06-29-2010, 05:52 AM
Ballz_F250's Avatar
Ballz_F250 Ballz_F250 is offline
Ballz_F250 is starting off with a positive reputation.
06silvercrew - My (NC) car just failed for having to dark of a window tint. I have 35% (legal). The first shop measured 29% (fail). Since I KNOW it is legal (it passed last year with the same meter at a different shop), I got the light transmissivity checked at a different shop...60%. I even went as far as to go to the police and they said it's legal because you can see the opposite door panel thru it.
So my question...I'm going back into the shop to have them re-check and re-calibrate and everything. If it still fails according to their machine...do you know what organization I can contact that would be in charge of inspecting the inspection stations?
Also...when the calibration is done on these photometers, isn't there a piece of glass they are supposed to use as a "baseline"? The first shop didn't use one...the second shop did.
Thanks in advance!
__________________
Ballz
1999 F-250 Super Duty XLT 4x4 V10
AEM Brute Force Intake
Superchips Programmer
Dual CherryBombs
  #8 (permalink)
Old 06-29-2010, 12:07 PM
Joelong258's Avatar
Joelong258 Joelong258 is offline
Joelong258 is starting off with a positive reputation.
Just roll your windows down when you go in then they dont see the tint. Thats what i did..(mines illegal)
__________________
Joe
1999.5 F250SD Lariat CC SB 4x4 With Tow+Off Road Package 225,000 DP Tuner(60t, 80e, 120r, lope, drive thru)
AutoMeter Z Series Gauges (Boost, Pyro, Trans)
4" Turbo Back Straight piped, Rollbak Bed Cover, 6637 w/ Riffraff Cover, IC Foil Delete, leveling kit, 33s
  #9 (permalink)
Old 06-29-2010, 02:56 PM
Ballz_F250's Avatar
They were rolled down. But you can see that the back window is tinted. And they are obligated to roll them up to check for tint.
I've got my ducks in a row tho...I'm going to go in and ask them to recalibrate it again...and if they don't use the sample glass as stated in 19A NCAC 03D .0551 of the North Carolina Department of Transportation Division of Motor Vehicles License and Theft Bureau Regulations...then we'll have some words about my refund for not performing the inspection properly.
__________________
Ballz
Dual CherryBombs
  #10 (permalink)
Old 06-29-2010, 07:19 PM
EPNCSU2006's Avatar
A guy at work just finished ripping out his tint for this very reason, although his was illegal. He was going to take it to another shop to have it passed, but was told that once the inspection is started and entered into the computer, you have to have it re-inspected at the same place - I have no idea if that is true or not.
__________________
Eric
  #11 (permalink)
Old 06-29-2010, 07:42 PM
Ballz_F250's Avatar
There is some truth to that. If you get the issue corrected, you can take it back to the original shop within 60 days (I believe) and have it reinspected for free.
But you can take it to another shop, you just are going to have to pay the 33.75 again (including tint).
__________________
Ballz
Dual CherryBombs
  #12 (permalink)
Old 06-29-2010, 07:46 PM
The meter should be calibrated EVERY USE!!!!! each meter has a calibration glass with it, takes 4 seconds to do it.
No you dont have to take it back to the same place to get it re-inspected but you will have to pay full price, where if you take it back to the same place you only pay for the E-sticker. It used to be 30 days, might be 60 now not sure.
__________________
-Scott
SOLD 2-28-11.....
  #13 (permalink)
Old 06-29-2010, 07:53 PM
Ballz_F250's Avatar
Yesterday they didn't use the glass to cal. it...just went face to face and it showed 100%...but when they put it on my windows it read 29%.
The second opinion shop used the glass and cal. it at 100% and when they checked my windows they were reading between 55% and 60%.
Went back to the original shop today and when I asked them to recal. it again...they did then I mentioned the glass and they sort of huffed and puffed and did but didn't let me watch them. And rechecked the car...not letting me watch...and still said 29%.
Now I've got 70% factory on there...and had 40% aftermarket put on...no way in hell that's enough to push it to 29%. Not to mention that it passed with flying colors last year and the police even say it's legal...soooo...License and Theft Bureau will be hearing from me regarding this.
__________________
Ballz
Dual CherryBombs
  #14 (permalink)
Old 06-30-2010, 06:07 AM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
1995 Ford F-350
Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.
Hey Silvercrew,
Does NC consider a turbo a muffler? Last year I had my powerstroke straight-piped and they failed it for no muffler, bought a 4" glasspack (8" long lol) and it passed.
Just curious because I know some states count a turbo as a muffler.
__________________
Brownie (Evan) Ooh-Rah! Once a Marine Always a Marine Oregon Chapter Member
'95 F350 CC 4x4 - 7.3 PSD, 190k, Built E4OD, SRW Conv, 4x4 Conv, Rosewood Stage I's, PHP Chip, 6637 Intake, 3" DP, Lost Kitty, 4" Exhaust, 3" RSK, 38 gal rear tank, fuel vent mod, 140v IDM, HPX, FPR Shim, 3.55 gears
'10 Escape, 200hp 3.0 V6, 4x4 - Stock
  #15 (permalink)
Old 06-30-2010, 11:24 AM
Ballz_F250's Avatar
Update on my issue.
Turns out there was something wrong with the second shops meter that showed 60%. Tried to take it to them today and it showed 29%...so he graciously stopped and asked if I really want to pay another 33.75.
Bottom line...I took it back to the original place...apologized for being a pain...peeled my front two windows and the rear window. They let me keep the back 2 corners (car is a coupe), so I could prove to the tint shop that they aren't legal.
Since I have a receipt showing lifetime warranty for legal tint...I'm going to visit the tint shop this weekend and get them re-tinted...to the legal limit...for free...minus the 2 corner windows.
Thanks for the help and advice.
__________________
Ballz
Dual CherryBombs
Tags
carolina, ford, inspection, license, light, lights, motor, nc, north, pass, plate, requirement, requirements, reverse, state, vehicle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
