Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 04-07-2010, 04:01 PM
ExpyBob ExpyBob is offline
Garage is empty, add now
ExpyBob is starting off with a positive reputation.
2007 Ford Grille Badge, replacing--help please
My new insert has blue stuff over what I think is adhesive on the back.
Is the factory one stuck on with the clips and two sided foam tape?
If so how do you get it apart?
Thanks guys---Bob
__________________
Bob
  #2 (permalink)
Old 04-07-2010, 05:28 PM
gddyup's Avatar
gddyup gddyup is offline
gddyup is gaining momentum as a positive member of FTE.gddyup is gaining momentum as a positive member of FTE.
BERRY!!! TYLUS!!!.... where are you guys!! Gimme a bit to find them. They're probably outside under their Expys trying to find new ways of giving them the 6-Million-Dollar-Man treatment. You know... Better, Stronger,Faster!!....
  #3 (permalink)
Old 04-07-2010, 05:51 PM
Huh? It was delivered today. Just need advise.
__________________
Bob
  #4 (permalink)
Old 04-07-2010, 06:42 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Click the image to open in full size.
Hard to tell if it's just double sided tape or there are clips. Look at the back of the grille, crawl underneath the truck with a light. If you see two tabs at the back of the grille where the emblem is, there is your answer.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #5 (permalink)
Old 04-07-2010, 06:45 PM
berry1234's Avatar
8C3Z1542528A
Looks like double sided tape with 3 small tabs for alignment. Heat gun and some work should get it off.
__________________
  #6 (permalink)
Old 04-07-2010, 08:04 PM
I'll do that. I don't have a heat gun though.
I was thinking about adhesive remover or fishing line. Saw it off with line.
I have the exact one in the picture. Hair dryer ??
And thanks for getting back. Most appreciated. Very much so.
Bob
__________________
Bob
  #7 (permalink)
Old 04-07-2010, 08:07 PM
Holy crap Batman, rivets? I thought it was clips or something easily removed.
__________________
Bob
  #8 (permalink)
Old 04-08-2010, 10:53 AM
berry1234's Avatar
ExpyBob, PM me with your email I will send you more details on this.
__________________
  #9 (permalink)
Old 04-08-2010, 12:34 PM
Hi Berry1234
I went ahead and sent it to you.
Thanks.
__________________
Bob
  #10 (permalink)
Old 04-08-2010, 02:37 PM
hjsimpson's Avatar
hjsimpson hjsimpson is offline
2007 Ford Expedition
hjsimpson is starting off with a positive reputation.
When I replaced my chrome grille with a black one I needed to swap the original Ford badge as well. There are two plastic posts on the back of the badge and they are held in from behind the grille with (metal) push washers.
They are a pain in the butt and I ended snapping one of the tabs. I need a replacement badge cause I have severe cracking and bubbling on the plastic overcoat...but local "stealership" wanted $50 for one.
__________________
2007 Ford Expedition XLT 4X4
Husky Liners Molded Mud Guards ~ Ford OEM Side Window Deflectors ~ WeatherTech Floor Liners & Cargo Liner
Tinted front windows ~ Hunter Bull Bar ~ HIDX 4" HID lights ~ 4" Magnaflow SS rolled angle exhaust tip
Quote:
Never, never, never give up. -Winston Churchill
  #11 (permalink)
Old 04-08-2010, 02:40 PM
Thanks. Every time I open the thread the pictures are different.
I'm going to try it Saturday.
__________________
Bob
  #12 (permalink)
Old 04-08-2010, 03:46 PM
berry1234's Avatar
Sorry, I copied the link from the alldata site. Refer to the email.
__________________
  #13 (permalink)
Old 04-09-2010, 06:50 AM
Harley Guy Harley Guy is offline
Harley Guy is starting off with a positive reputation.
Just replaced mine. The original one did not have the adhesive tape. Pull the big upper shroud/cover and you can get your hand down in the area behind the emblem (barely). 2 8 mm nuts, remove them. I used a 1/4" ratchet and deep socket. You may need to pry the old emblem out - I used 2 putty knives but first put masking tape around the area to keep from messing the paint up. Install is the reverse.
B/R,
Randy
  #14 (permalink)
Old 04-26-2010, 02:22 PM
PastorTramp PastorTramp is offline
PastorTramp is starting off with a positive reputation.
Where did you buy?
Where did you buy your part? If you dont' mind, how much?? Thanks.
  #15 (permalink)
Old 04-26-2010, 03:07 PM
berry1234's Avatar
I am seeing part number 8C3Z1542528A for about $15 online from Ford Parts Guy.
www.partsguyed.com
But when I search the grille parts for the 08-07 is shows up as $34. Strange.
__________________
Tags
07, 2002, 2007, 2008, badge, el, emblem, emblems, expedition, f250, ford, grill, grille, superduty, truck, tylus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
