Torque specs. and pattern for 7.3.....
Out of the book
Cauton: Do not use too much engine oil on the threads of the cylinder head bolts,or damage to the threads and poor sealing can result. Do not use anti seize compounds,grease or any other lubricants except engine oil on the cylinder head bolts threads because they will affect the truce torque value reading of the bolts
Tighten the bolts in sequence, shown in 3 stagesStage
1. Using the first sequence tighten bolts to 88NM(65lbFT)
2. using the 1st seuence tighten the bolts to 115 Nm(85lbFT)
3. Using the 2nd sequence tighten the bolts to 129NM (95LBFT)
Sequence
in the center of the head upper is#1 below is 2 then from there go counter clock wise
Sequence #2 start on the bottom rear bolt work your way forward in rows the last bolt will be upper inside bolt closest to the front of the motor
Sequence
junkyardjeff
12-12-2016 09:13 PM
Chris 73
04-28-2006 08:50 PM
DannyP
03-23-2004 09:43 PM
