Did the SPD Y-pipe upgrade. - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-07-2010, 01:30 PM
Gastic3514's Avatar
Gastic3514 Gastic3514 is offline
Gastic3514 is starting off with a positive reputation.
I couldn't find the old thread we all talked about this, so created this new one.
I put on the SPD Y pipe yesterday. Only took a couple of hours, the vast majority of which is cutting, fitting, cut a little more, fit some more.
Anyhow, that is all I changed was the Y-pipe. In the previous thread I had mentioned that 2 years ago I had replaced the P/S manifold studs with the improved Ford pieces, due to the originals breaking. About a year after that I developed another leak and figured the bolts had snapped yet again. I was wrong! The manifold had a small rust hole / crack in the bottom near the block, but I was able to weld that up.
Eventually I will be adding a new muffler, the stock one is leaking where the straps hold the heat shield.
But I did nothing but the Y-pipe so I could verify its benefits.
Sound: I think the truck has a little deeper tone at idle. While driving, you can hear the exhaust a little in the Y-pipe area under the floor. Its not a leak, you can just hear the hollow sound of exhaust flowing through the pipe.
Performance: Off-idle throttle response is much more instantaneous. At low RPM I can feel a big difference. I mashed it a few times up to about 60mph, feels like the motor revs a little quicker. I have not towed anything yet, and I think that is where I will see a big improvement.
Does it add the claimed 33 hp? I don't know, thats a lot for just a Y-pipe upgrade but the stock piece HAS to kill at least 15hp.
I am very happy with the change, recommend it to anyone's truck with that piece of poo stock pipe.
Old 04-07-2010, 03:02 PM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
Thanks for the info. Can you post a link to where you got yours along with cost? Thanks!
Old 04-07-2010, 03:17 PM
Gastic3514's Avatar
SPD Performance I bought the stainless version, because of the salt during the winter in Ohio. Mine was $129.00.
Old 04-07-2010, 05:24 PM
That's great! Thanks very much.
Old 04-07-2010, 10:22 PM
NM04FORD's Avatar
NM04FORD NM04FORD is offline
NM04FORD is starting off with a positive reputation.
Did mine about a year ago, the throttle response was greatly improved. And so far a year later it still puts a smile on my face when I hit the loud pedal. Put a cc cheby in its place the other night, he was looking at tail lights.
Old 04-07-2010, 10:25 PM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold
Thanks for the detailed report!
That's the same pipe I bought, but I haven't put it on yet. I hope to do this sometime in the next couple weeks.
Old 04-08-2010, 08:05 AM
Gastic3514's Avatar
Careful when cutting out the original Y-pipe. The factory steel is double walled and tuff! Get many sawzall blades. You will see that after the Y, the exhaust heads towards the Cat. There is a bolt together union just before the cat, just ahead of a cross member. All the vibration from the saw broke the pipe off at that union. I had to re-weld that as well. Wasn't too big of a deal, bud it did add to the work.
Old 04-08-2010, 08:26 AM
GUNNERDOG's Avatar
GUNNERDOG GUNNERDOG is offline
GUNNERDOG has a very good reputation on FTE.GUNNERDOG has a very good reputation on FTE.GUNNERDOG has a very good reputation on FTE.GUNNERDOG has a very good reputation on FTE.
Im in the same boat. I bought the SPD Y about 2 months ago, but haven't had the time to get it into the shop. I don't own a welder, so i called the local exhaust shop. They quoted me only $80 to do it... I just hope all that vibration doesn't pop off all my exhaust manifold studs...
Maybe i will request that they use a plasma cutter to get the old pipe out.
Old 04-08-2010, 08:34 AM
Gastic3514's Avatar
I would say the new piece should flow just a bit better!
Last edited by Gastic3514; 04-08-2010 at 08:36 AM. Reason: Photo link didn't work.
Old 04-08-2010, 09:54 AM
PERFORMANCE RED PERFORMANCE RED is offline
PERFORMANCE RED is starting off with a positive reputation.
Is this y pipe mostly for the 99-04 trucks? I swear my Y pipe looks nothing like the one in the picture above. I have an 07 V10.
Old 04-08-2010, 11:17 AM
GUNNERDOG's Avatar
Yep, i think the 07 has dual cats... its a much better setup.
Old 04-08-2010, 12:36 PM
XL1200LTD-Keith's Avatar
XL1200LTD-Keith XL1200LTD-Keith is offline
XL1200LTD-Keith is starting off with a positive reputation.
Old 04-08-2010, 01:03 PM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
To me, with my '01, which already had ebay headers and a VOlant intake, the y-pipe did NOT increase the max HP.
If DID however greatly increase the throttle response at low RPMs. Much nicer to drive in stop-and-go traffic, but overall I don't think it really added anything to the max HP.
On top of those mods, I added the 5-star 87 octane performance tune, and went from a 10 second 0-60, down to a 9.02-9.04 second 0-60, confirmed with datalogging. Amazing
Old 06-05-2014, 03:26 PM
cold_beer839's Avatar
cold_beer839 cold_beer839 is offline
cold_beer839 is gaining momentum as a positive member of FTE.cold_beer839 is gaining momentum as a positive member of FTE.
Is SPD Performance still in business? I placed an order on their website and paid via Paypal a week ago and haven't received a shipping notice yet and the phone number listed on their webiste does not get answered by SPD.
Old 06-05-2014, 03:34 PM
Aero750 Aero750 is offline
Aero750 is starting off with a positive reputation.
Quote:
this is an old thread but to answer your question yes they are still in bussiness. i went thru the same problems as you. i ordered mine and one month to the day it was on my door step when i got home from work. still sitting in the box it came in as i havent had the time. but be patienent it will come
Hedman Hedder install w/pics ak-angler Modular V10 (6.8l) 298 07-11-2016 07:04 PM
Dynomax Y-Pipe powerstroke8806 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 03-29-2016 02:09 AM
Real results from 351w exhaust upgrades needed compman Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 9 06-08-2015 08:18 PM
Y-pipe doesn't quite fit the shorty headers bdad57 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 11 07-05-2006 05:53 PM
Catco Y pipe BC478 1987 - 1996 F150 & Larger F-Series Trucks 1 06-01-2005 10:08 AM
Tags
1996, 2000, 2001, 60, adding, cats, f150, f250, ford, lightning, pipe, pipes, spd, upgrade, v10, ypipe
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
