Cold Morning, Dead Battery - Ford Truck Enthusiasts Forums
Old 01-27-2003, 04:31 PM
MW95F250's Avatar
MW95F250 MW95F250 is offline
MW95F250 is starting off with a positive reputation.
This morning I go out to start my truck and I put the key in and all I hear is just click, click, click. The only thing that was on was my cell phone and that is hardwired in. I thought it could be just the cold weather causing it. I was wondering if a block heater would help prevent this from happening again. It's a '95 F-250 460. I know block heaters are primarily for diesels, but is it possible for mine to need one? I live in NC and this year its been colder than normal, so that's why I suspect the weather. Thanks.
Old 01-27-2003, 04:42 PM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
A block heater won't help the battery, but a battery heater might. More likely, it's a bad connection. If you can twist the battery terminal clamps by hand, they're too loose. If they can't be tightened, replace the cables. Use a 4-way terminal tool to clean & resurface the terminals for the best connection.
Old 01-27-2003, 04:43 PM
mrwizard's Avatar
mrwizard mrwizard is offline
mrwizard is starting off with a positive reputation.
I'm pretty sure the block heater wouldn't have done anything for your situation. They main reason for a block heater is to keep the oil warm so it moves through the engine much faster on startup than if the oil was extremely cold. The main benefit for the driver (other than not hearing lifters clatter around for several seconds) is the heater warming up much faster.
If your truck has shown a tendency to crank slowly when it's very cold outside, then one might help. You didn't mention how old the battery is, or if it's even the original one in the truck. Cold weather will definately sap the energy from a battery, especially if it's on it's last legs anyway. It might just be time for a new battery. Just to make sure though, I would get the alternator tested. Most places do it for free anyway.
Old 01-27-2003, 05:16 PM
RichB RichB is offline
RichB is starting off with a positive reputation.
Talking Cold Morning, Dead Battery
Greetings from the land of 10000 degrees below zero. Yup if your battery is over 3 years old the cold can kill em at any time. BTW colder weather has been known to let the bead on a tire leak a bit or even let loose. Wouldn't hurt to check the air in the tires
Old 01-27-2003, 08:34 PM
MW95F250's Avatar
Problem Solved!! Went to Advance Auto Parts, got it tested and it registered weak. So I went ahead and bought a new battery with more CCA's so I won't be let down by that other one again. Thanks for all the advice.
Old 01-27-2003, 08:38 PM
steve83's Avatar
Next time, I highly recommend the MotorCraft Silver Series battery. It has an 8-year warranty and the first 3 are free replacement. ~$80
Old 01-27-2003, 09:22 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
The battery should be changed every 3-4 years. Lots of times people think its fine all summer long and the first time it's cold that battery just dies. Good prevenative measure is to change it before it leaves you stranded.
No start in cold mornings choskins 1999 - 2003 7.3L Power Stroke Diesel 8 10-24-2016 01:21 PM
'01 F250 serp. belt bigcountry1009 1999 to 2016 Super Duty 1 10-24-2014 07:43 PM
2007 F250 Clicking when changing temp from cold to heater for air conditioner andysam 1999 to 2016 Super Duty 2 02-25-2014 05:51 PM
1979 F250 Block Heater Indy443 1973 - 1979 F-100 & Larger F-Series Trucks 10 11-07-2013 02:04 PM
Cold weather kits mahd776 6.0L Power Stroke Diesel 1 01-06-2010 07:00 AM
Tags
04, 2000, battery, block, clicking, cold, dead, diesel, f150, f250, flat, ford, heater, plugged, series, short, silver, truck, weak
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
