Ok guys. My buddys got a 2000 f250. The truck will run for 2 min and then shut down. It will white smoke the whole time. Has brand new injectors, new gp, HPOP tested good, and new injector harnesses.
Any ideas. Running out of em quick. Hes got it at a shop and im just trying to help him out. Powerstroke is not my best subject. Just got one so im learning.
Are they injectors brand new? or remans? from where? There are a couple of not so good rebuilders out there. Is the SES light coming on? Have you pulled any codes?
After replacing injectors there is a lot of air in the system and it takes a while to purge it out.
Sounds like fuel delivery problem for me. Could be air in the lines, could be fuel flow restrictions. Installing pressure gauge on fuel bowl would answer that .
What exactly made him change all those parts out? If it was based on the shops recommendation, tell him to get the truck out of there as they are just throwing parts at it. If he changed all those parts before the problem, then we need to look at what was done before it started.
Thanks guys
I just replaced my high pressure oil pump and mine did the same thing! Sounds like the egr or transmisssion coler to me I am having to do the same thing on mine! Damn ford 2003 and up are a pain and junk in my opinion!
Welcome to the forum! 7.3's don't have egr stuff. Maybe your are talking about a 6.0 leaker.
