Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1948 - 1956 F1, F100 & Larger F-Series Trucks Discuss the Fat Fendered and Classic Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 04-06-2010, 11:44 PM
polarspeed's Avatar
polarspeed polarspeed is offline
1951 Ford F-Series Pickup
polarspeed is starting off with a positive reputation.
6V Temp Sensor for 302 intake?
Hello, I am trying to convert my stock gauges for my 51 F1 to the 302 SBF intake manifold. The temp sending unit is huge. Has anyone gotten this to work for either the stock 2V intake manifold or the Edelbrock Performer Intake manifold (#2121)? I have the speedo issue solved so that it can be used with my 5 speed manual transmission, but waiting on the oil pressure sending unit. Is there a 6V sending unit for oil pressure? I can't find one.
Thanks, Steve
  #2 (permalink)
Old 04-07-2010, 12:01 AM
Julies Cool F1 Julies Cool F1 is offline
Your Posting Princess!
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
Why don't you convert to modern mechanical gauges that will fit your engine, that you don't have to voltage reduce and you don't have to adapt 6 volt electrical sending units that are expensive to buy - if you can find them.
Adapting 3 1/2 inch Supro mechanical gauges into your existing gauge cases and using the stock faces is a relatively simple process that only requires some minor cutting of the stock gauge case.
Look in my Galleries. There is a gallery that tells you the step by step and has a picture of each step.
I have done this with my oil and temp. Ammeter does not need to be modified, and gas gauge can be voltage reduced.
Here is a picture of my gauge package after the conversion:
Name:  N. New gauge assembled.JPG
Name:  9. Guage Package Restoration.JPG
  #3 (permalink)
Old 04-07-2010, 01:19 AM
HD74's Avatar
HD74 HD74 is offline
Garage is empty, add now
HD74 is starting off with a positive reputation.
I'm using the old oil pressure sending unit with my 12v system. I just added a voltage drop to the gauges. As noted in the picture and it works fine. On the amp meter make sure you run the wire thru backwards or it will show that your discharging instead of charging.
Click the image to open in full size.
As your looking at the back of the gauges, normal 6v pos. grd. would run thru the hoops bottom to top. 12v neg. grd. start at the top loop than down and around to the breaker bar.
__________________
1951 F-1 w/French Flathead V8
2001 Road Glide
2008 Bobber
1981 FLH
  #4 (permalink)
Old 04-07-2010, 08:00 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
1952 Ford F-Series Pickup
ALBUQ F-1 has a great reputation on FTE.ALBUQ F-1 has a great reputation on FTE.ALBUQ F-1 has a great reputation on FTE.ALBUQ F-1 has a great reputation on FTE.ALBUQ F-1 has a great reputation on FTE.ALBUQ F-1 has a great reputation on FTE.
Doug51F1 has installed the stock flathead type sender in his 302.
__________________
Ross
1952 F-1 Flat V8 3-on-the-tree
Other projects/vehicles: '86 Porsche 944; '91 H-D FXRS
Tags
1952, 302, 83, 89, coolant, f100, f150, ford, sender, sending, sensor, temp, temperature, testing, unit, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
