Engine Rattle - Ford Truck Enthusiasts Forums
Engine Rattle
Old 01-27-2003, 03:14 PM
jerseyjeff1978 jerseyjeff1978 is offline
jerseyjeff1978 is starting off with a positive reputation.
Engine Rattle
I own a 2002 XL 2wd with a 4.2 and an auto trans. When I drive at speeds between 40 and 55 I hear a rattle coming from under the hood. When I hit the gas hard it goes away, and when I let off the gas it goes away. It almost sounds like pinging but it dosen't do this under load. I dont think it is an exhaust leak but I dont know for sure. I have looked under the truck and found no loose exhaust, or any sign of leakage. I have also tried to get it to make the noise when it is sitting in neutral but it wont. It only does this when I am moving. Has anyone else experienced this? Any input would be greatly appreciated.
Jersey Jeff
Old 02-20-2003, 07:10 PM
rhetor rhetor is offline
rhetor is starting off with a positive reputation.
Engine Rattle
hey,
i know this is overly simple and may sound stupid, but sometimes these things get you. Is there something hittin the fan blades? Maybe there's a piece of plastic or something next to the fan that gets blown in at a certain speed.
Old 02-20-2003, 08:26 PM
Thumbs up Engine Rattle
thanks for giving me some ideas!
you know, I never thought of that! thanks for the idea, I am going to check it out in the morning.
jersey jeff
Old 03-08-2003, 02:49 PM
Spyder369 Spyder369 is offline
Spyder369 is starting off with a positive reputation.
Engine Rattle
sup man i got a 2002 f150 4.2v6 xlt. i clocked mine on the rpm meter. mine happens when it hits 1 to one 1.2 rpm's. when it idle nothing happens and when i go over 1 to 1.2 rpm's it goes away. now when i drive it at 1-1.2 rpm's it there. thats around your 30 mph scale also. i took it to the ford and they found rocks in the converter shield. check your converter shield man. could be the problem. and take it to the ford service place or a guy who knows how to fix things. laterz
Old 03-13-2003, 11:25 PM
big6 big6 is offline
big6 is starting off with a positive reputation.
Engine Rattle
Hey JJ, did you get it fixed? I think my 4.2 has the same condition, it makes a light pinging at steady-state throttle at cruising rpm.
On mine I am sure it is simply pinging, as it disappeared when I tried some premium. I think in my case I may have an intake leak which is not helping the problem, hopefully you do not either.
Old 09-09-2011, 11:07 PM
SaintsFan83 SaintsFan83 is offline
SaintsFan83 is starting off with a positive reputation.
Did anyone ever figure this out? The original post is EXACTLY what my 4.2 is doing. This is the only noise my truck makes and I have to drown it out with the stereo......
weird rattle sound under acceleration Thumper19 1987 - 1996 F150 & Larger F-Series Trucks 12 06-13-2012 01:00 AM
What is that INFERNAL RATTLE!!!!! jerem0621 1997 - 2003 F150 3 03-23-2012 09:17 PM
Rattling sound cainster 2004 - 2008 F150 1 10-01-2010 07:34 AM
Peculiar Noise Jeff Dodson 1997-2006 Expedition & Navigator 2 04-11-2009 11:20 AM
Problem on my truck oricle 1987 - 1996 F150 & Larger F-Series Trucks 0 03-19-2006 03:36 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1971, 1987, 2002f150enginerattle, 302, 42, clatter, engine, f100, f150, ford, hood, ingine, rattle, rattles, truck, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
