You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Gentlemen, am considering buying a 65 econoline pickup with a newly installed 289 (my first econo). My big concern is whether this engine will require a larger than standard radiator or other measures to provide proper cooling for highway driving (Northern CA). Also will this engine generate heat in the cab and will insulating the dog house cause any problems. Thanks for your help
Hey welcome to FTE! I don't know the answers to your questions but I do have a 289 in a 64 Falcon convertible and those cars were initially designed as small sixes so the radiator design is pretty small. Still fine for it though. I'd try it out and then decide if you need an aluminum radiator or something for it.
__________________
Andy
2012 Race Red Boss 302 "Commuter Car" Early 99 F250 PSD 4x4 CC 6spd Common Mods 260,000+ Miles, Driven daily like a rented mule
1964 Falcon Convert 289 Toploader 9" 4 Wheel Disks
Nov '10 Recipient: "dedicated report-back tech thread poster" award!
The 65 Econolines have bigger rads than the early ones. It should work fine.. They are hooks to either a 240 or 300 engines. So they produce lots of heat.
The doghouse were only insulated on the lids. It does get warm, but I just open the vents.
The 289 wasn't available in Falcons until 1965. 1963 1/2's & 1964's were only available with the 260.
The radiator is different with V8's than it is for I-6's. The same radiators used in 1963/65 Falcon's were also used in 1965/66 Mustangs.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
Thanks Bill. I put the 289 in about 22 years ago or so. What I meant was the physical size or the radiator, height and width, was established before the decision to add the V8. And for the record, doesn't the radiator in a Falcon have a slightly different inlet-outlet configuration than the Mustang?
__________________
Andy
In my experience, anything less than a 4 core radiator will get hot in a V8 econoline. I bought a 4 core rad for a 67 mustang, had my radiator guy swap the mounting brackets -left side to rt, rt to left- Then it'll bolt right up. You may have to use a bit of imagination to line up rad hoses, but its SO worth it in the hot summers.
