Heater blower motor problems - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 01-27-2003, 02:05 PM
TnBroncoII TnBroncoII is offline
TnBroncoII is starting off with a positive reputation.
I have an '85 Bronco II with the 2.8 engine and AT. I have noticed that the heater blower motor does not really put out very much air except on the highest setting. It has a 4 position switch, but I can tell very little difference in the first three settings.
On the highest position setting there is pretty good air flow but maybe not as much as it should be. Is there a way to adjust this without replacing motor...And if not, how much is involved in replacement? Thanks very much. I enjoy this forum!
Old 01-27-2003, 02:22 PM
Matt_W Matt_W is offline
Matt_W is starting off with a positive reputation.
The first thing to do is to remove the heater bower motor. it is just three tiny bolts in the engine compartment near the cab on the passanger side. Very often this will be filled with leaves and all sorts of other stuff that will restrict airflow. If you are only getting high speed for your blower then it is most likely the blower motor resistor. There are lots of posts on this problem as it seems to be very common so you can search for it for some good information. (Basicly its a pack of resistors) It is located close to the blower motor. It has a 6 sided plug with about 5 (?) wires goin into it. Its another easy thing to replace. i got one from a junkyard for 5 bucks. i dont know what ford charges. If you think its somewhere else in the circuit i can give you the testing procedure but you will need a multimeter or self powered test light. Hope this helps some.
Old 01-27-2003, 04:49 PM
Thanks for the reply. I removed the blower motor and there
were no leaves or debris inside. I removed the resistor pack and there were some leaves in there that I vacuumed out. I inspected all the coil wires and there were no obvious breaks or burned places but I suspect this unit is the problem. I checked and could not find an aftermarket source....so I guess I will check with the local junk yards. I don't want to pay Ford dealer prices!
Thanks again for your help!
Old 01-28-2003, 10:27 AM
AlM's Avatar
AlM AlM is offline
AlM is starting off with a positive reputation.
yo,
Is this what you need?
http://www.napaonline.com/cgi-bin/nc...grpid=28175376
Echlin Ignition Blower Motor Resistor Connector
Click on image to see enlarged view
Front Item#: ECHEC4
Price: $ 8.49
tax and shipping not included
Usually ships in 24 hours.
Attributes:
Attributes: Blower Motor Resistor Connector
Warranty: Limited 12 Months
Add to Cart
Return to Previous Page
New Search
There is no Material Safety Data Sheet (MSDS) available for this Product
Old 01-28-2003, 11:10 AM
That appears to be the connector that plugs in to the part that I need. I need the resistor pack itself.
Thanks for trying to help!
Old 01-28-2003, 09:13 PM
tolvibman tolvibman is offline
tolvibman is starting off with a positive reputation.
I believe the part you are looking for is quite standard for a Ford and readily available at your friendly neighborhood boneyard. I know I picked up a couple plus the connector on one of my trips.
Old 01-28-2003, 09:44 PM
I picked up a resistor pack today from a local yard. That was the problem, and now the fan works fine. $2 well spent. Thanks for your help!
Why is my accumulator frozen when using heater? 1998Ranger25L153CID Ranger & B-Series 1 11-23-2015 07:54 AM
Blower not working on 1995 Diesel (powerstroke) E350 danielcoyle 1968-2013 Full Size Vans 6 05-31-2014 06:46 AM
Heater Fan Speed Switch fishinpole Excursion - King of SUVs 0 08-21-2013 01:10 AM
Sport Trac Blower Motor Resistor Location Cal357 Explorer, Sport Trac, Mountaineer & Aviator 9 04-02-2011 11:15 AM
Help!! - fan control switch only works on two highest settings andruszh 1997-2006 Expedition & Navigator 2 09-18-2004 02:20 AM
Tags
blower, bronco, f350, ford, heater, motor, problem, problems, troubleshooting, truckheater
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
