Go Back   Ford Truck Enthusiasts Forums > Marketplace > Want to Buy > WTB - Parts & other
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
  #1 (permalink)
Old 04-05-2010, 11:43 PM
E30tdf's Avatar
E30tdf E30tdf is offline
1986 Ford F-250
E30tdf is starting off with a positive reputation.
WTB: 1986 460 Thermactor Emissions Parts
If anyone has the thermactor emissions parts for a 460 F250 (I think 85-86-87 would all work), I'm in need. I had a freak situation where my air cleaner held some water and it was sucked into the thermactor pumps, control valves and check valves. Thought I had blown a head gasket and the truck sat a while this Winter. Consequently the thermactor moving parts are now rusty and screwed up inside. For sure I need the check valves and control/deverter valves that control the air flow from the pumps to the air manifolds. Let me know what you have and what you want for them. Got to be some of this emission stuff lying around in garages .....surely?
Have to pass 1 more emission test and I'm exempt. Isn't that the way it goes sometimes! Had the emissions all up to snuff and this happens!
I know someone will ask how the water got in. Leaking cowl to hood seal!
Thanks
Tom
  #2 (permalink)
Old 04-07-2010, 11:15 PM
xirxious xirxious is offline
Garage is empty, add now
xirxious is starting off with a positive reputation.
What part is that exactly? do you have a pic? I live in Everett and got my '86 460 to pass last year. You're welcome to it if its there. The previous owner tore ALOT out and I had to 'trick' the sniff test a little...The air pump is gone already.
  #3 (permalink)
Old 04-08-2010, 10:49 AM
E30tdf's Avatar
1986 Ford F-250
Pictures of Parts
Quote:
Thanks for the reply [SIZE="3"xirxious[/size]......I'm failing the hydrocarbons and carbon monoxide at idle. Passes the cruise portion of the test. Had the thermactor all up to snuff and then sucked water through the thermactor system. The inside of the check valves are all wet and rusty. Have not looked into the deverter valves.
Need check valves for sure (but they will be a Bi*tch to get off the air manifolds. The get hot and freeze as result. Also would take deverter valves if someone had them.
Here are the pics (if the upload works).....thanks.....Tom
  #4 (permalink)
Old 04-08-2010, 08:11 PM
E30tdf's Avatar
1986 Ford F-250
I was able to find both pumps and the rear vacuum controlled air diverter valve at the Tacoma Pick A Part Yard today off an 87 extended cab. The air manifolds with the check valves (I only need the check valves) were already gone. You never know how good these parts are from a salvage yard truck. That truck was lost to a carberator fire. The forward control valve near the back of the smog pumps was damaged by the fire. The parts were less than $40 and I have 30 days to return if they don't work. They look reasonably good.
  #5 (permalink)
Old 04-10-2010, 09:00 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Are you aware that FTE has a Ford Dealer Parts Dept sponsor in WA?
PARTSGUYED.COM. Ed is the parts manager of Horizon Truck Center in Tukwila, Millennium Ford in Burien.
Ed gives FTE members a parts discount off the actual MSRP.
If you need info, pictures, or parts prices, or wanna swing on by and look at the parts catalogs, contact Ed for assistance. There is no charge for these services.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
Tags
1986, 1987, 460, 86, aerostar, air, control, controls, emission, emissions, engine, f250, ford, managed, parts, pics, thermactor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
