Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > New England Region > New Hampshire Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
New Hampshire Chapter Join Chapter Leader: 7283-F250
  #1 (permalink)
Old 04-05-2010, 10:50 PM
unclejunk's Avatar
unclejunk unclejunk is offline
1979 Ford F-350
My Garage
unclejunk is starting off with a positive reputation.
351 m or 351w
trying to decide wether i want to run a 351w or 351m like the m alot even though most people do not but all so have 351w from mid to late 70s out of a boat that really puts out some rpms dont know what to choose any thoughts
  #2 (permalink)
Old 04-06-2010, 08:34 PM
05rangeredge's Avatar
05rangeredge 05rangeredge is offline
Garage is empty, add now
05rangeredge is starting off with a positive reputation.
im thinking that the boat motor is designed to make peak numbers at high rpms, so if your not keeping the rpm's up, it might bog down or have no *****. whats the difference between a windsor and a modified?
  #3 (permalink)
Old 04-06-2010, 08:57 PM
mud bros's Avatar
mud bros mud bros is offline
mud bros is starting off with a positive reputation.
after having many ford engines under my right foot it all comes down to 2 things when picking a engine for a 4500lb truck.
1.cash on hand.
2.what you think is cool
there is not many engines that ford put in trucks with under 300ft lbs of torque hp went from 150-325 so you can pick any v8 you wish(if the tq is already there its easy to tap into the missing hp numbers).
now the real importent question is this!
what transmission and rear axle ratio do i need to run this engine effectively for*enter intended usage here*?
  #4 (permalink)
Old 04-07-2010, 11:09 AM
7283-F250's Avatar
7283-F250 7283-F250 is offline
NH Chapter Lead Pawn
1972 Ford F-250
My Garage
7283-F250 has a great reputation on FTE.7283-F250 has a great reputation on FTE.7283-F250 has a great reputation on FTE.7283-F250 has a great reputation on FTE.7283-F250 has a great reputation on FTE.7283-F250 has a great reputation on FTE.
for lack of better terms big block or small block (Ya I know those are chebby terms).
351w are also more plentiful if you end up popping it. (most of the 80's some of the 90's in in f-series - bronco's - vans)
351m can be turned back into a 400 if so desired.
I think you might be able to find EFI for the 351w where as you would have to either hunt for aftermarket 351m EFI or rig somthing up. Of course that is if you wanted to go that route. I also think 79 is the last year for the 351m.
The 2 motors require differant motor mounts and trannies so once you pick it you'r kinda stuck. Unless you don't mind another project to swap it over.
__________________
New England Region -- NH Chapter -- Join NH Chapter
07 Ranger FX4 - 72 F250(has a 2012 inspection sticker on it) - 68 F250 - 01 Focus
  #5 (permalink)
Old 04-07-2010, 10:42 PM
unclejunk's Avatar
1979 Ford F-350
My Garage
c6 automatic trans i have one for the m and one also to fit the w iam going to run 2.5 ton millitary axles with a 673 gear ratio and at least a 56in tractor tire s
  #6 (permalink)
Old 04-07-2010, 10:46 PM
unclejunk's Avatar
1979 Ford F-350
My Garage
i was thinking about using a 400 cranck and rods going 40 over on the m block then you run into the old overheating thery i no the m is also mcc cast wich were also not so great but it is out of a 78 so i think i will b ok
  #7 (permalink)
Old 04-08-2010, 08:30 AM
7283-F250's Avatar
1972 Ford F-250
My Garage
Quote:
Originally Posted by unclejunk View Post
i am going to run 2.5 ton millitary axles with a 673 gear ratio and at least a 56in tractor tire s
Just get a 502 crate motor
or find a 7.3L diesel. How bout that new 6.3L turbo diesel.
Or if RPM's are a problem how bout a rotery motor. I don't think the red line is untill somewhere near 10K RPMs
I know... I know... You use the stuff kicking around.
__________________
  #8 (permalink)
Old 04-13-2010, 08:34 PM
unclejunk's Avatar
1979 Ford F-350
My Garage
there still i do have a 7.3l non turbo in a 88 f250 i got kickn around here mayb
  #9 (permalink)
Old 04-13-2010, 08:55 PM
7283-F250's Avatar
1972 Ford F-250
My Garage
There you go.
Watch u-tube. diesels seem to do prety well to put out stuck gassers....
__________________
Tags
1995, 351, 351w, 400, 88, block, bogs, early, ford, mudding, overheating, truck, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
