89 fullsize Bronco 4x4
Year: 1989
Make: Ford
Model: Bronco
Price: $690
Mileage: 152000
Color: red/white
Private or Dealer Listing: Private Listing
Location (State): NJ
Transmission: Manual
Drivetrain: 4WD & AWD
Color: Red
Engine: 5.0 302 v8 fuel injected
It ran and drove great before the clutch randomly gave out about 2 days ago. the steering and suspension are tight and it stops great because it had all new front brakes put on not too long ago.-- new tires. it was a daily driver.
- it has a good running 302 5.0l v8 engine, fuel injected, no smoke and no noises, runs great has plenty of power.
-good 5 speed manual trans, m5r2
- good transfercase (4x4 works good), manual shift <<<<< reliable
- WARN PREMIUM, manual locking hubs <<<< reliable
- GOOD rear end. 8.8 ford will fit trucks/broncos etc. 3.55 gears with factory limited slip posi unit , WORKS GREAT. brakes are good.
TAILGATE IS RUST FREE. its solid underneath. body isn't in too bad of shape compared to most bronco's. no floor rust, etc..
here's some pics-
located in pennsville, nj 08070. can be at philly airport in 30 minutes. 5 minutes from delaware mem. bridge.
email- pbawboy67@aim.com
thanks
Pictures
I can't see the pics at work. Can you pm or email me some. Thank you. I'm in Ct.
email: mckayt@aetna.com
It's in parts and peices bud....too late.
Only thing left is the motor, rear, tailgate, doors, Tcase.....I sold the trans and fenders,bumper/grille
hay that souds great i beed a body straight frame just totaled mine frames bent body knock off eveny thing else i good what r you asking for what you have left and do you have a title
hey fastcat i sent you a visitor message.
I'll take $400 for it as it sits with no motor/trans/t-case...
I'll sell it to you rolling, it has good front and rear axles 3.55 limited slip, frame is good, tailgate is good, right front fender is good. $400 it's yours and you bring your own wheels and tires to swap on because for $400 these brand new tires ain't going with it. Call - 856-678-7883
Where you locateD?
Where you locateD?
I have a clear title for the bronco.
I'm 5 minutes from the Delaware Memorial bridge. pennsville, new jersey 08070
Last time i went to Dover it took me about 1 hr and 15 min.
Call- 856-693-0918 David
