700 miles from home and truck quit
On vacation with the wife and kids. This morning the wife takes the truck to the store I asked her to fill it up while she was out because it was getting pretty low. She came back and said she couldn't find any diesel. So I jump in to go fill it up I backed out the parking spot and it started running bad it wouldn't even pull back into the spot. I called my roadside service to bring me fuel. They brought two gallons. I started it back up and headed to the gas station. Made it a mile with it running bad then it died. Called roadside again and told them to bring me five gallons this time. An hour later I got the fuel and made it to the gas station but it was still running terrible. Filled it up and made it another mile and it died again. Waited awhile and got it restarted made it most of the way and it died again. I gave some time got it restarted and made it back. Is it possible it just won't reprime or did I fubar the fuel pump or injector pump or something else. I have an appt at ford in the morning. So Im hoping I didn't mess anything up. I'm in clermont Florida outside of Orlando I hope they have some good techs here.
The immediate suspect is the fuel and filters...
Sounds like fuel starvation.
Don't panic... don't assume the worse (fuel injectors, etc.) yet.
Lets see what the facts say.
Did you try draining some fuel out of the Fuel Conditioning Module and see what it looks like ?
Is it making the sound it normally does (pumping) when you turn on the ignition (but before you start).
Are you waiting until the line is pressurized before you attempt to start?
While you are down there... disconnect the electrical connectors, if you have a volt meter, check the voltage.. and if needs be clean the contacts.
BTW, if you can document that it is a bad tank of fuel... it might be covered under your comprehensive insurance.
Good luck!
Good luck!
Unfortunately I don't have any tools with me. I was hoping it was just clogged filters. I never payed attention to what the fuel pump sounded like before. I can hear it running now and it runs for almost a minute. If I let it sit awhile and restart it it will idle rough but stay running. When I drive it's like it runs out of fuel again. So I guess either a weak pump or clogged filters. I guess next time I'll pack a tool bag.
I would think the fuel quality was ok. I ran that tank out with no problems although it did drop about 1mpg on that tank. It does sound like it's starving for fuel. I thought about taking a taxi. I had to use one this afternoon to go pick up my wife's asthma meds and it cost $20 to go 2 miles and back. So if I spend taxi money buy the tools and filters and it doesn't fix it I would freak out. The nearest ford dealer is 20 miles away and my roadside will cover the tow. I guess I'll just send it to them and pay them. Lesson learned. Hopefully just filters and it won't cost me to much. Thanks for the replies and I'll post when it's done.
DSMMH
DSMMH
