08 Superduty whistles / squeals when accelerating over 2000 RPM's - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 04-05-2010, 03:12 PM
golfswithbeer's Avatar
golfswithbeer golfswithbeer is offline
golfswithbeer is starting off with a positive reputation.
I have noticed in the past weeks that my 2008 F250 squeals when I accelerate and the RPM is usually between 2000-2500 RPM's. If I let off or "floor" it, the squeal goes away. It is very loud, not like a belt or air whistle. I don't really notice a power performance differerance. I was thinking it could be turbo related and maybe it has more to do with the psi of the tirbo and less with the RPM's.
ANY IDEAS???? Anyone else have something similar? Warranty just expired 03/22/10.
Old 04-05-2010, 06:00 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
have you checked your belts and pulley's to be sure everything is tight? That is about the only thing I would think it is.
You can check your CAC hoses and make they are tight as well.
Old 04-05-2010, 06:45 PM
kane gray's Avatar
kane gray kane gray is offline
kane gray is starting off with a positive reputation.
Exhaust leak. Which unfortunately could mean cab off repair.
Old 04-05-2010, 07:26 PM
LaxPlaya21's Avatar
LaxPlaya21 LaxPlaya21 is offline
LaxPlaya21 has a very good reputation on FTE.LaxPlaya21 has a very good reputation on FTE.LaxPlaya21 has a very good reputation on FTE.LaxPlaya21 has a very good reputation on FTE.
Quote:
I wouldn't think a leak, beacause he said when he floors it it goes away. If it was a leak, I would think the whistle would get louder with more pressure...
Just speculating here, but maybe a turbo bearing? That is what happened in my 6.0. It would make this whisteling sound... needless to say I had the turbo rebuilt.
Old 04-05-2010, 09:50 PM
hunter08 hunter08 is offline
hunter08 is starting off with a positive reputation.
Mine was doing the same thing and found out it was the down pipe/y-pipe.See if it does it especially after sitting at an idle for a few moments then it gets loud when you pull out.Mine was stretching at gasket when idling and did not do it when moving.If this is it they will have it for a day.No cab off but a tranny drop.I thought it was my torbo at first.Hope this helps
Old 04-05-2010, 09:52 PM
Sorry i didn't put it was the exhaust.And i miss spelled turbo!
Old 04-06-2010, 08:26 AM
I don't think it is a belt issue. All belts seem tight. It only happens when accelerating and it has become worse over the past week. At first I thought a simple hose leak but now it is loud! When I accelerate, everyone stares at the noise and it is not a "pretty" whistling noise but more of a loud high pitch squeal. I think maybe turbo bearings but I was hoping someone else had similar issues. It only has 32,000 miles. My first Ford and I am a little taken back if the turbo has already gone bad.
Old 04-06-2010, 09:00 AM
senix's Avatar
check to make sure the coolant in the fuel/turbo cooler has coolant in it and is full and looks good in color.
Old 04-06-2010, 09:06 AM
I just had it in for an oil change 2-3 weeks ago and I would think that the dealership would have checked that???? I see no leaks from the hoses/clamps for the turbo cooler.
Old 04-06-2010, 11:39 AM
kane gray's Avatar
It really sounds to me like an exhaust leak.
Old 04-06-2010, 11:56 AM
Wouldn't an exhaust leak be continuous?? This is only when mildly accelerating. Once I reach 55 or so and I am just cruising, you can not hear it at all. You also can't hear if you take off real easy or take off real hard. It is only when normal acceleration is happening.
Old 04-06-2010, 07:09 PM
That sounds just like mine did.Have the dealer check the down y-pipe.Maybe the same thing good luck!
Old 04-07-2010, 11:02 PM
SANDDEMON08's Avatar
SANDDEMON08 SANDDEMON08 is offline
SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.
Depanding wat you call a squeal the early models had a TSB reguarding coolant makeing a similar noise going thru the heater core mine did it id have to dig up the fix but i think they just slow the flow down a little to make it go away.
Old 03-23-2016, 10:33 AM
tpjimmie tpjimmie is offline
tpjimmie is starting off with a positive reputation.
Did you ever find out the reason behind the squeal. Mine is doing this exact same thing.
Old 04-27-2016, 12:40 AM
Crea's Avatar
Crea Crea is offline
Crea is starting off with a positive reputation.
Quote:
Mine starting doing this exact same thing a few days ago. Any help this problem? Everything works same as before.
squels go away when motor warm as little bit....
There is promlem solver?
http://www.ford-trucks.com/forums/11...eration-2.html
HELP loud squealing sound drivers side / lift pump? Vicbrodeur 1999 to 2016 Super Duty 8 10-18-2016 09:30 PM
Turbo or Pipe Squeal EricE 1999 to 2016 Super Duty 7 10-13-2016 11:47 AM
Squealing noise when accelerating jmaskew 6.0L Power Stroke Diesel 15 11-27-2015 03:49 AM
squealing noise is driving me crazy twall_SD250 1999 to 2016 Super Duty 8 08-19-2011 08:31 AM
Squeal at Low RPM UWMtriebs 6.0L Power Stroke Diesel 2 03-05-2008 08:14 PM
Tags
1999, 2000, 2008, 73, accelerating, diesel, engine, f350, ford, noise, past, rpm, rpms, squeak, whistles, whistling
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
