hey guys anybody have an idea? i put it back together but it still leaks a little, i just dont want to strip anything, so if anybody has the tourque specs for the 420 diesel tranny pan bolts it would be much appricieated
I'm not sure what kind of gasket you have, but torquing the bolts to much can cause the gasket to squeeze out, you may also warp the tranny pan...but in your case I don't think 5 ft lbs will have any negative side affects.
