86 Speedometer gear in transmission stripped - Ford Truck Enthusiasts Forums
Old 04-05-2010, 03:25 AM
kona56 kona56 is offline
kona56 is starting off with a positive reputation.
Unhappy 86 Speedometer gear in transmission stripped
1986 Ford F250 4 speed 460
I've been thru the whole speedometer cable, had it out checked and lubed, if I pull it out of the transmission I can spin it freely and it moves the speedometer just fine if I spin it fast.
The little plastic gear at the end of the speedometer looks just fine, and I can feel teeth inside the transmission - the only thing I can think of is that the gear on the inside of the transmission stripped out.
Anybody know how to get that gear out, or know how to figure out if its stripped?
Thanks.......
Old 04-05-2010, 03:52 AM
Ken Blythen's Avatar
Ken Blythen Ken Blythen is offline
Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.
I had one apart on an NP435 transmission a few months ago, but the trans wasn't in a truck at the time.
If you can shine a light in the drive hole, you will probably be able to see if it's damaged.
To replace the NP435 speedo gear, I removed the yoke from the tailshaft, unbolted & removed the tailshaft housing, removed a circlip from the tailshaft & slid the drive gear off. It engaged on a small pin to drive.
You would need to support the transmission & unbolt the rear mount from the crossmember to do this, if still in the vehicle. I didn't have to bother about that, or even drain the oil, the trans was just sitting on the shed floor.
Old 04-05-2010, 07:55 AM
cracked lp cracked lp is offline
cracked lp is starting off with a positive reputation.
Speedo stripped
The tail housing is held on by 4 bolts. the speedometer gear is nylon and is colored to match the transmission. the nylon gear is on the output shaft and held on by two c-clamps, one in front and one in back. You will need a special pair of plyers to remove the c-clamp. The gear will slide off. WARNING. Do not pull on the shaft without the tail housing in place or it will separate from the transmission and the inter roller bearing, that you can't see, will spill into the transmission causing more problems. The tail houseing holds the output shaft in place and the shaft must not be allowed to shift backwards!! When you take the tail housing off there is nothing holding the output shaft from coming out the back.
Old 04-05-2010, 01:52 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
All the four speeds are relatively the same to get at the speedo drive gear in the transmission, T-18, T-19, and NP-435.
It's color coded depending on how any teeth the gear has. Either 6, 7, 8, or 9 depending on the rear end ratio, and the cut to the teeth, either left or right handed. This is different to the speedo cable gear on the end of the cable that is also color coded with teeth rangeing from 16 to 21 teeth and is to be matched with tire size.
You need to know the current rear end ratio of the truck, and/or the color of the gear inside the transmission to get the right one, or to get the right match.
If your speedometer is off, it would be a good time to replace the speedometer cable gear with the right set of teeth too.
Hope this helps.
Old 04-05-2010, 02:13 PM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Methanoholic
Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.
Best thing to do is, take your truck info, trans, rear ratio and tire size down to your local Ford Dealer and they'll match you a drive gear and driven gear and you'll be all set.
When I did mine (it's 4x4) I tried doing the step through each part thing and wound up with a mess because of the unavailability of some combinations.
Wound up letting them match availability up and presto, they got me a pair that was correct.
-Enjoy
fh : )_~
np435 speedometer gear detent/hold/retainer f-250.4x4.390 1973 - 1979 F-100 & Larger F-Series Trucks 2 07-22-2015 03:12 PM
1981 F100 speedometer problems my996duc1 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 09-22-2014 01:42 PM
Speedometer problems limeyellowfellow 1967 - 1972 F-100 & Larger F-Series Trucks 3 05-15-2012 08:26 AM
Spedometer gear in transmission stripped. arnegrant 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 08-05-2009 12:20 PM
speedometer doesn't work when truck is cold sigtauenus 1973 - 1979 F-100 & Larger F-Series Trucks 7 02-15-2007 02:22 PM
Tags
1980, 1991, 86, automatic, f150, f250, ford, gear, pin, removal, removing, replacement, speedo, speedometer, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
