You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
just got my truck reflashed and 30 mins later the wrench light came on, the truck runs fine and the light goes off if i truck the truck off then on again but then comes back on the next day......does anyone know what it means?? should i be worried???
__________________
2005 f250 6.0 FX4 crew cab lariat SB, egr delete, ARP head studs, SCT F3 with Matts custom tunes (Gearheads), BD diesel boost builder, zoodad, ccv rr, updated turbo drain tube, AFE 4in turbo back exhaust, volant ram air intake, 2009 f250 20in wheels with 325/60 terra grapplers, RDS 60 gallon toolbox/tank, JVC 7in. touchscreen CD/DVD stereo,5%tint, high idle mod on AUX switch #4, NAPA coolant filter and more to come....
The only time that I've ha the wrench come on is when I had forgot to put my program in the truck and my turbo built up about 40+ psi of boost. Got a strange reaction from the truck, really hard to describe and then it was like in "limp mode". I knew it was because of too much boost though. However, since you said the truck runs fine, I doubt it's that unless I just over reacted about "limp mode".
I wouldn't know where to begine though on this without looking at the codes to see, even if it's just in general, what is going on with the truck.
Damn that sucks. I'll bet it's the new temperature differential between EOT and ECT that now sets a CEL it the temps are 15*F apart. Do you like your dealership?
im not getting a check engine im getting the wrench light??? i never realy take the truck to the dealer since im out of warranty just went for the reflash
__________________
Wrench is really serious.
Take it to the dealer and at least, get the codes read now.
It can be things like failure of the accelerator pedal.
oh chet!!!!!!!!!....realy that bad????!!!i just took a 3hr trip to work wont be going back till next month....does it have to be a ford dealer scanner or can autozone scanners pull the codes????
__________________
Go to the nearest place with a scanner to lend you... see what it reads.
Then, as warranted.. go to the nearest Ford dealer.
Really --- have it looked at.
I am the king of logging and deleting CEL codes... and I don't ignore the wrench light.
AFAIK, the wrench light may automatically mean you are in "limp" mode...
Find someone with a good CAN scanner that can read more then just the general powertrain module. What would show up on an autozone reader(if anything) might just give you a general indication. Better then nothing, but it could still leave you wondering what it is.
From my one experience with the Wrench light, I would say that it's limp mode til it gets fixed. Could be wrong, but based on my experience, I was in limp mode when it came on for me.
It's not as serious as folk are making it sound; the latest flash uses the "wrench light" to notify the operator of several "out-of-spec" readings that could lead to typical major 6.0L problems. 1-FICM low voltages (FICM Failing), 2-Oil Cooler Efficiency (EGR & Oil Cooler Replacement), & 3-Turbo Overboost (Head Gaskets). If no hard cold starts & you are just driving normally when the light comes on ... suspect the Oil Cooler Efficiency.
If you were not gitting it before the flash, then there's your answer.
Also, I got a fancy CAN enabled code reader ... but it still will not retrieve the disappearing "wrench light" code. It's gotta be stored somewhere ...
__________________ 2006 Ford F-250 Super Crew Lariat FX4 6.0L PSD
If I still had the code I could tell you what module it was in with AE, but alas I don't.
[quote=98SurplusExpy;8732661the latest flash uses the "wrench light" to notify the operator of several "out-of-spec" readings that could lead to typical major 6.0L problems.[/quote]
Can you tell me what month / year flash started to do this?
That way, I can make sure I don't flash again until the OBDII readers catch up with it.
