Transmission Removal - 2004 F-150 5.4L 4WD
Old 04-04-2010, 09:50 PM
JRROTH1's Avatar
JRROTH1
JRROTH1 is offline
I am replacing the flexplate in a 2004 F-150 Supercab 5.4L 4WD. Does any one know the secret for getting to and removing the two transmission-to-engine bolts on the top of the transmission??
JRR
2004 F-150 SuperCrew 5.4L 4WD
2008 F-150 SuperCrew 5.4L 4WD
Old 04-04-2010, 10:09 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Long extension over the top of the trans? Is there any access with a wrench from the top?
Old 04-04-2010, 11:20 PM
stuart1's Avatar
stuart1
stuart1 is offline
Lower the transmission and use a long extension with a swivel socket.
Old 04-04-2010, 11:54 PM
JRROTH1's Avatar
JRROTH1
JRROTH1 is offline
By "lower the transmission" - do you mean remove the crossmember and lower the rear end of the transmission a little to make more room on top?
JRR
Old 04-05-2010, 12:16 AM
stuart1's Avatar
stuart1
stuart1 is offline
Yes.
The cross member should have been removed by now.
It has to come out to replace the flex plate.
Old 04-05-2010, 09:11 AM
JRROTH1's Avatar
JRROTH1
JRROTH1 is offline
The crossmember is removed but I was afraid to lower the trasmission. I didn't know how far I could go and didn't want to risk damage to the motor mounts without asking the best way to get those bolts out. Besides - this trick is not in the Ford manual . . .
So would this be the correct procedure (starting with all transmission-to-engine bolts installed:
1. Lower the rear end of the transmission and remove the upper bolts. How much can I lower it?
2. Raise the transmission and remove the remainder of the bolts.
3. Remove transmission and replace flex plate.
4. Install transmission - lower bolts.
5. Lower the rear end of the transmission and install/torque the upper bolts.
6. Torque the remaining lower bolts
Thanks -
JRR
shawnvhs2003
1997 - 2003 F150
08-17-2021 09:16 PM
steve2003
1997 - 2003 F150
04-03-2017 07:05 PM
jes775
09-23-2016 12:45 PM
tower1121
03-09-2016 06:33 PM
breeze12
2004 - 2008 F150
04-27-2009 05:10 PM
Quick Reply: Transmission Removal - 2004 F-150 5.4L 4WD
