Transmission Removal - 2004 F-150 5.4L 4WD - Ford Truck Enthusiasts Forums
Old 04-04-2010, 10:50 PM
JRROTH1 JRROTH1 is offline
JRROTH1 is starting off with a positive reputation.
I am replacing the flexplate in a 2004 F-150 Supercab 5.4L 4WD. Does any one know the secret for getting to and removing the two transmission-to-engine bolts on the top of the transmission??
JRR
2004 F-150 SuperCrew 5.4L 4WD
2008 F-150 SuperCrew 5.4L 4WD
Old 04-04-2010, 11:09 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Long extension over the top of the trans? Is there any access with a wrench from the top?
Old 04-05-2010, 12:20 AM
stuart1 stuart1 is offline
stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.
Lower the transmission and use a long extension with a swivel socket.
Old 04-05-2010, 12:54 AM
By "lower the transmission" - do you mean remove the crossmember and lower the rear end of the transmission a little to make more room on top?
JRR
Old 04-05-2010, 01:16 AM
Yes.
The cross member should have been removed by now.
It has to come out to replace the flex plate.
Old 04-05-2010, 10:11 AM
The crossmember is removed but I was afraid to lower the trasmission. I didn't know how far I could go and didn't want to risk damage to the motor mounts without asking the best way to get those bolts out. Besides - this trick is not in the Ford manual . . .
So would this be the correct procedure (starting with all transmission-to-engine bolts installed:
1. Lower the rear end of the transmission and remove the upper bolts. How much can I lower it?
2. Raise the transmission and remove the remainder of the bolts.
3. Remove transmission and replace flex plate.
4. Install transmission - lower bolts.
5. Lower the rear end of the transmission and install/torque the upper bolts.
6. Torque the remaining lower bolts
Thanks -
JRR
transmission id tag jes775 Clutch, Transmission, Differential, Axle & Transfer Case 2 09-23-2016 01:45 PM
Avg mpg for 2004 F150 5.4l? shockr4 2004 - 2008 F150 22 02-13-2014 11:26 PM
Minimum rotor thickness carljungm 2004 - 2008 F150 5 05-30-2012 11:41 PM
2004 F-150 5.4L 3V cvt selenoid robertfrieson 2004 - 2008 F150 1 01-20-2012 08:31 AM
SWAP A 4.6L FOR A 5.4L chris5301 1997 - 2003 F150 10 01-03-2010 12:42 AM
Tags
2004, 4wd, 54, 54l, bolts, drive, f150, make, remove, removing, room, tranny, transmillsion, transmishion, transmission, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
