cab mounts
cab mounts
Does anyone have pictures of the front cab mounts you can share. My truck's prev owner cut them off and I do no know what they look like. (48 f1)I looked in some catalogues but They do not have detailed drawings,
does the entire cab rest on rubber mounted front and rear cab mounts?
Do you mean the metal part on the front of the cab? Classic Haulers catalogue page 76 has new ones listed. My cab is upside down and I can take pictures if you like.
There are six mounts, two at the very front, two on the floorboards inside by the door pillars and the floating bracket thing-a-bobby by the rear of the cab, the front four use rubber mounts / washers. I think the front maybe should have a shoudered bolt because the cab is supposed to float, but mine just had bolts?
