2001 Super Crew F-150, 5.4 buzzing....
Have a 2001 w/5.4 180,000 miles. Been noticing a buzzing noise from the the valve cover/ injector area lately. Thought it might be the alt. but noise is to the left of it. Checked the A/C pump and seems O.K. Actually the A/C pump isn't even running at when it buzzes. I shut off the heater blower fan thinking it might be the fan, it still made the buzzing sound. When you start the engine it starts to buzz but when you shut it off, the buzzing stops a second or two after the engine is completely stopped. I did this several times to make sure the engine was stopped and it was. Can it be an injector? It's been doing it for several months and getting louder. At first when I heard it at start up, it would stop after a few seconds then go away or I could shutoff the engine and restart and it would be gone. Now it is constant. You can't hear it in the cab but outside you can. Any ideas? Thanks funtwohunt
I don't know if the buzz your hearing or not but I started a thread a long time ago about hum/buzz I had"
https://www.ford-trucks.com/forums/6...ater-hose.html
2001 f-150 5.4l buzzing
I am having the same buzzing sound, dies down about 2 seconds after the key is turned off. Was wondering if anyone could describe in detail how to just remove the regulator in the heater hose so I don't have to go through the process of replacing the hoses....there is two heater hoses correct? Which one has the regulator in it?....any info would be greatly appreciated
smith148
03-28-2017 03:38 PM
jdneal88
16
01-02-2017 12:35 AM
1'stonraceday
18
09-14-2015 08:50 AM
